General Information > Troubleshooting
1.6 NA not getting fuel
UncleDelicious:
I really appreciate all of the suggestions from everybody. I just ordered a MityVac and I'll swing by AutoZone to get some diesel purge after work some day this week.
I'll let you know how I make out once I get the MityVac up and running
fatmobile:
Put a clear hose on the output of the filter and suck through it.
You should be able to suck fuel from the tank easily.
It it's pulling hard there is a restriction.
UncleDelicious:
The MityVac is able to pull fuel up through the filter relatively easily
I was unable to get it to fire back up though due to possibly the starter. I'm going to put the new starter in today and see where that gets me
UncleDelicious:
It was starting and running so well from that external fuel supply a couple weeks ago.
I can't even get it to turn over anymore. The starter clicks and that's about all I get, even when jump starting it while trying to start it. I also went around and cleaned up some of the grounds but nothing.
kljaja:
I had a "click" noise from starter relay and nothing after with bad battery...
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
