General Information > Troubleshooting
1.6 NA not getting fuel
UncleDelicious:
I haven't gotten around to this governor screw yet.
The tranny code on the bottom says 12012
When I upshift it is totally out of the power band. I'll max out a gear and then when I upshift it feels like I have 0 power until I am able to build the rpms back up
There always seems to be air in the return line as well
ORCoaster:
YOU MUST FIX THIS FIRST!!!!!!
Otherwise you will never know if getting power is happening as it should or not.
I suspect seals are in need of replacement on the IP or you have an inlet line that is cracked or loose IN bolt seal.
Navigation
[0] Message Index
[*] Previous page
Go to full version
