Author Topic: AAZ crank bearings quick question  (Read 2415 times)
May 17, 2017, 09:50:15 am
simonfredette
  • 8
« on: May 17, 2017, 09:50:15 am »
I just noticed that the bearing kit I received comes with 4 flat bearings and 6 bearings with an oil channel, is this intended and if so which bearing cap gets a channelled bearing on top and bottom? Also, does anyone have a picture of the proper orientation of the thrust washers under #3, dont want to mess that up either. Thanks guys
Reply #1May 17, 2017, 11:29:09 am
Dakotakid
  • 1240
Re: AAZ crank bearings quick question
« Reply #1 on: May 17, 2017, 11:29:09 am »
From a parts supply house:
"WARNING! Volkswagen OE design modification. Set contains (1) lower bearing shell which is grooved and WITHOUT OIL HOLE. Install in # 4 CAP position only!"
Reply #2May 17, 2017, 12:44:47 pm
simonfredette
  • 8
« Reply #2 on: May 17, 2017, 12:44:47 pm »
thanks Ill check , wonder what the reasoning is ..
Reply #3May 17, 2017, 02:52:16 pm
Dakotakid
  • 1240
« Reply #3 on: May 17, 2017, 02:52:16 pm »
Oil supply splits directly above.
