Author Topic: Lf: injector pump parts  (Read 4436 times)
April 15, 2017, 10:28:16 am
Ian0391
  • 119
« on: April 15, 2017, 10:28:16 am »
This may be a long shot but I snapped this black plate, it's originally out of a landrover 300tdi pump. Does anyone have one or a parts pump?
Sent from my SM-G920W8 using Tapatalk
Reply #1April 15, 2017, 05:57:52 pm
Re: Lf: injector pump parts
« Reply #1 on: April 15, 2017, 05:57:52 pm »
I am not quite sure which part you are referring to here.  The part below the springs, normally referred to as the pump head or are you asking about the plate above the springs?
Would a Bosh one fit OK?
Reply #2April 15, 2017, 08:12:07 pm
Ian0391
  • 119
« Reply #2 on: April 15, 2017, 08:12:07 pm »
I'm looking for the plate on top
Reply #3April 21, 2017, 10:16:54 pm
« Reply #3 on: April 21, 2017, 10:16:54 pm »
You can most likely use one off a TDI pump and I can probably get you one if needed.
Reply #4April 22, 2017, 06:23:41 pm
Ian0391
  • 119
« Reply #4 on: April 22, 2017, 06:23:41 pm »
Thanks but I actually grabbed one out of a 1.6td pump, measured them up and they're identical
