Author Topic: Tach on 1.6D???  (Read 4036 times)
March 24, 2017, 10:02:49 am
Tmarkle
  • 153
Tach on 1.6D???
« on: March 24, 2017, 10:02:49 am »
So I tried to wire in an Autometer tach to my VW, I bought a new alternator from NAPA (old one was bad) and it happened to have the W terminal, so I thought, sweet! I can wire in a tach! well I tried to wire it in and for whatever reason the tach goes from 0-4k rpms on startup and doesnt look like its moving properly... Ideas???
1985 Jetta 1.6 NA, Project
1981 Rabbit 1.5 diesel SOLD
1980 Dasher, also a project
1993 Passat GLX VR6 (daily driver)
1992 Toyota Pickup, 350 V8 swapped
1997 Jetta TDI, engine donor for a diesel powered Toyota!
1986 Toyota Custom Cab
Reply #1March 24, 2017, 10:51:52 am
Re: Tach on 1.6D???
« Reply #1 on: March 24, 2017, 10:51:52 am »
Do you have a proper signal from the W terminal? I think you're looking for 8 VAC.
Reply #2March 24, 2017, 01:18:44 pm
Tmarkle
  • 153
Re: Tach on 1.6D???
« Reply #2 on: March 24, 2017, 01:18:44 pm »
Honestly didn't check. I'll test it and see.
Reply #3March 24, 2017, 02:49:36 pm
Re: Tach on 1.6D???
« Reply #3 on: March 24, 2017, 02:49:36 pm »
Is the Autometer tach for a gas engine?  If so, it will not work with the W terminal.
Reply #4March 24, 2017, 06:35:16 pm
Re: Tach on 1.6D???
« Reply #4 on: March 24, 2017, 06:35:16 pm »
...at least not without an adapter.
As you've noticed the alternator signal is much higher frequency than a gasser ignition signal which is what that tach is expecting.
Reply #5March 24, 2017, 06:47:01 pm
Tmarkle
  • 153
Re: Tach on 1.6D???
« Reply #5 on: March 24, 2017, 06:47:01 pm »
Where would I get such an adapter? Yes it's for a gasser, I bought it for another project and thought I would utilize it for this car.
Reply #6March 24, 2017, 06:48:13 pm
Re: Tach on 1.6D???
« Reply #6 on: March 24, 2017, 06:48:13 pm »
Dakota Digital make the only adapter I know of that's premade. I've never had to use one.
Reply #7March 24, 2017, 07:19:17 pm
Tmarkle
  • 153
Re: Tach on 1.6D???
« Reply #7 on: March 24, 2017, 07:19:17 pm »
Could one make their own adapter?
Reply #8March 24, 2017, 07:36:45 pm
Re: Tach on 1.6D???
« Reply #8 on: March 24, 2017, 07:36:45 pm »
There's a few examples around the forum where people have used a magnetic pickup and a magnet or two attached to the IP or cam pulley to trigger a gasser tach.
Reply #9March 24, 2017, 07:56:56 pm
Re: Tach on 1.6D???
« Reply #9 on: March 24, 2017, 07:56:56 pm »
There are quite a few tach options available:
Get a stock diesel tach for your model and run it off the W terminal.
Get a stock gasser tach for your model and replace the necessary components to turn it into a diesel tach and run it off the W terminal.
Add an inductive probe and a couple lugs to drive a gasser tach off the crank.
Get a Tinytach and run it off a piezo pickup on an injection line.
Get an optical sensor kit from 4crawler and run a gasser tach off it.
Get the Dakota Digital signal conditioner and run a gasser tach off the W terminal.
I've personally done the first three options and they each can work fine.  I like the stock tach look so tend to go that direction.  There are probably other options that I'm forgetting.
Reply #10March 25, 2017, 12:48:53 pm
Tmarkle
  • 153
Re: Tach on 1.6D???
« Reply #10 on: March 25, 2017, 12:48:53 pm »
Ok thanks I'll see what I can figure out!
