Author Topic: no oil to turbo  (Read 14460 times)
Reply #15March 10, 2017, 05:49:49 am
Re: no oil to turbo
« Reply #15 on: March 10, 2017, 05:49:49 am »
I'd peek at the lifters before I run it much more... if they go up and down when you turn it by hand, they might be ok.
Reply #16March 10, 2017, 09:37:02 am
Re: no oil to turbo
« Reply #16 on: March 10, 2017, 09:37:02 am »
im back in the workshop on sunday, so ill crack em one by one with the motor running. one of the injectors, 4th if facing engine, has a fair amount of sealent on it! someone also recommended removing the aux belt and running it? anything else i can try on sunday? got the whole day to work on it! anyone in london wanna come have a look? i make a banging bacon sarnie!
Sealant all over the injector? Sounds like someone tried to "fix" something already...
I wouldn't be surprised if the goop-covered injector tries to unscrew itself in the middle when you try and loosen the hard line.
Reply #17March 11, 2017, 01:28:22 am
Coz
  • 12
Re: no oil to turbo
« Reply #17 on: March 11, 2017, 01:28:22 am »
right. just started her up, and cracked the injectors one by one. to my ear it sounds like the knocking goes away when i undo the 3rd injector from the left when facing the engine. now what? ive only owned this pos for about 6 weeks and its spent 3 off the road!!
Reply #18March 11, 2017, 08:49:22 am
Re: no oil to turbo
« Reply #18 on: March 11, 2017, 08:49:22 am »
That pretty much confirms that you need your injectors rebuilt. The knocking sound is caused by the injector leaking fuel before it is supposed to. If left like that it can cause engine damage.
Reply #19March 24, 2017, 02:43:56 am
Coz
  • 12
Re: no oil to turbo
« Reply #19 on: March 24, 2017, 02:43:56 am »
got the lump stripped down. there was no rings on the third piston!! it was rattling around in the bore! so having a full rebuild, managed to source a block, piston etc.
Reply #20March 24, 2017, 07:56:05 am
Re: no oil to turbo
« Reply #20 on: March 24, 2017, 07:56:05 am »
Props to ya for hanging in... lotta folks would walk away.
Reply #21March 25, 2017, 02:42:49 am
Coz
  • 12
Re: no oil to turbo
« Reply #21 on: March 25, 2017, 02:42:49 am »
i hate giving up. this motor is gonna be reliable as *** and good for years to come!
Reply #22April 16, 2017, 05:23:07 am
Coz
  • 12
Re: no oil to turbo
« Reply #22 on: April 16, 2017, 05:23:07 am »
the caddys back with a fully rebuilt motor and nos bottom end! everything has been replaced and it starts and runs. other than some new electrical issues, it starts ok, but still isnt quite running right. ive fitted an egt gauge from stack, so i can monitor temps, and waiting on an oil pressure gauge. can someone point me in the direction of a guide to reset the pump to standard fuelling?
