Author Topic: AAZ head and k24, plus random parts  (Read 4623 times)
February 26, 2017, 06:42:23 pm
RunninWild
  • 609
« on: February 26, 2017, 06:42:23 pm »
I'm going to be pulling my engine and rebuilding the bottom end, installing my new head and a holset turbo in mid March. As such I will no longer be needing:
AAZ head, was told the engine had 175,000km on it when pulled. When I installed it the engine had almost no oil pressure. Ended up changing the main, rod and im shaft bearings and now I have too much oil pressure (believe an oil gallery is clogged). Anyways the engine runs extremely well other then the oil pressure issues. Here is a vid of it running from a couple months ago
Looking for $150USD for the just head with no valve cover, or coolant flanges
K24 with unknown miles, I believe there was no in and out shaft play and only minor up and down when I installed it but can give a better description when its pulled. I will include the oil feed line and my hacked up drain line for the aaz for $150USD obo. I may or may not have a spare manifold laying around as well.
1.6td injector lines $30USD
I'll have a look at my parts pile and update the thread with whatever else I can find. Like I mentioned earlier I'll be pulling the engine mid march so the parts wont be available until then. I'm in Canada so keep that in mind for shipping quotes.
Reply #1February 26, 2017, 08:25:11 pm
Re: AAZ head and k24, plus random parts
« Reply #1 on: February 26, 2017, 08:25:11 pm »
Pm'ed...is this the one we were discussing?
Reply #2March 15, 2017, 07:03:46 pm
RunninWild
  • 609
« Reply #2 on: March 15, 2017, 07:03:46 pm »
Cam looks to be in good condition. I'm pulling the engine and will have the head ready for shipping by next week. I'll take some pictures of the bottom and the pre-cups when its out.
Reply #3March 16, 2017, 08:50:19 pm
Tmarkle
  • 153
« Reply #3 on: March 16, 2017, 08:50:19 pm »
Still have the turbo? Maybe the manifold also?
1985 Jetta 1.6 NA, Project
1981 Rabbit 1.5 diesel SOLD
1980 Dasher, also a project
1993 Passat GLX VR6 (daily driver)
1992 Toyota Pickup, 350 V8 swapped
1997 Jetta TDI, engine donor for a diesel powered Toyota!
1986 Toyota Custom Cab
Reply #4March 16, 2017, 09:21:36 pm
RunninWild
  • 609
« Reply #4 on: March 16, 2017, 09:21:36 pm »
turbo is pending. The head is junk, cracks between the valves and precups. Good thing I decided to rebuild the block before it grenaded. Anyone need a AAZ Cam?
Reply #5April 19, 2017, 07:16:45 pm
jstamper
  • 11
« Reply #5 on: April 19, 2017, 07:16:45 pm »
How bad are the cracks in the head
