Model Specific Questions and Info
MK1 Golf/Jetta and B1 Dasher
KKK K14 Turbo "bee-hive" wastegate gasket
Topic: KKK K14 Turbo "bee-hive" wastegate gasket (Read 13004 times)
January 02, 2017, 02:07:07 pm
dailydubber
Newbie
January 02, 2017, 02:07:07 pm »
I'm a newbie on diesels and as well as turbos. I plan on putting a turbo on my '81 Rabbit 1.6 diesel NA. I scored a CY code 1.6TD and it came with a kkk K14 turbo but the individual I got it from said it needs rebuilding. So I bought a rebuild kit for it. I went ahead and removed the "bee-hive" waste gate to try cleaning it. As I took it off, I noticed that under the wastegate there seems to be some kind of gasket on the wastegate actuator. So that brings me to my question: do K14's have a gasket for the bee-hive wastegate actuator?
January 03, 2017, 06:47:24 am
dailydubber
Newbie
Re: KKK K14 Turbo "bee-hive" wastegate gasket
January 03, 2017, 06:47:24 am »
Nothing?
Come on, I know some of you diesel gurus out there know something about this. Spill the beans guys come on.
January 03, 2017, 08:10:28 am
January 03, 2017, 08:10:28 am »
K14's do have a gasket at the base of the wastegate actuator. I have reassembled 10+ of them and removed the gasket and smeared Permatex Ultra Copper on the mating surface and on the bolt threads. Never an issue.
January 04, 2017, 08:57:50 am
dailydubber
Newbie
January 04, 2017, 08:57:50 am »
Thanks libbydiesel. I actually emailed gopopshop and they confirmed that there is a gasket for the wastegate actuator. The reason I had asked this question is because as I took my actuator off, a quarter of the gasket crumbled off. Now gopopshop suggested to make my own gasket out of anything fireproof because they are no longer available. Anyone know where I can get one? If not I'll have to make my own
January 04, 2017, 05:03:22 pm
January 04, 2017, 05:03:22 pm »
As I mentioned, I've assembled many of them with just a smear of Permatex Ultra Copper (available everywhere) between the wastegate and turbine housing and a bit on the bolts. I've never had any issue going that route.
March 10, 2017, 04:44:24 am
kljaja
User+
March 10, 2017, 04:44:24 am »
I actually sanded the mating surfaces and tightened the actuator without gasket or anything inbetween, works well, no leaks, 10psi straight on boost gauge
Going fast never killed anyone, suddenly becoming stationary, thats what gets ya
February 23, 2019, 10:55:51 am
Timothycrock
Newbie
KKK K14 Turbo "bee hive" wastegate gasket
February 23, 2019, 10:55:51 am »
Evening all
Question: has anyone ported the wastegate without removing the turbo? Seems a shame to take everything apart if I dont really have to...
Ad
https://www.sportzfuel.com/
May 03, 2019, 02:01:03 pm
byronEsset
Newbie
May 03, 2019, 02:01:03 pm »
450 shipped for the pair. Comes with a free DV
300 Shipped for just the manifold.
180 Shipped for just the Wastegate and all 5 springs.
https://thefreehreportonpsu.com/noocube-review/
May 06, 2019, 09:38:05 am
Rock3tman
prev: 60typ2, 68pickup, 79rabbitD. now: 83jettaTD
May 06, 2019, 09:38:05 am »
I've had great luck putting McMaster-Carr p/n 1820K42, nuclear grade anti seize (up to 2400 degrees F) on all exhaust manifold & hotside turbo bolts, nuts, VNT mechanism, etc. After 10-50K miles driving I can remove parts with no drama.
