Author Topic: WTB: Non-AC Alternator Bracket/Alt Pulley  (Read 3923 times)
December 26, 2016, 07:06:53 pm
phish32786
  • 8
« on: December 26, 2016, 07:06:53 pm »
Hey all,
Doing an AC delete, '86 MK2 1.6NA one of the ears on my compressor broke off. Looking for the bracket mostly but if you have the alternator/pulley as well and want to bundle I'll take that as well.
Thanks all!
Mike
Reply #1December 26, 2016, 07:34:46 pm
Re: WTB: Non-AC Alternator Bracket/Alt Pulley
« Reply #1 on: December 26, 2016, 07:34:46 pm »
In the meantime, maybe you already know:
There are 4 ears equally spaced around the compressor.  I think you use 2 of the ears to install it.  If 1 ear breaks, unbolt the compressor, rotate it 1/4 turn and reinstall using a fresh ear and the broken one is in a position that is not used.
http://vwdiesel.net/forum/index.php/topic,20270.msg154665.html#msg154665
Reply #2December 27, 2016, 04:32:49 am
phish32786
  • 8
« Reply #2 on: December 27, 2016, 04:32:49 am »
Huh I didn't! Thanks for the tip!
Reply #3January 01, 2017, 07:22:16 am
phish32786
  • 8
« Reply #3 on: January 01, 2017, 07:22:16 am »
Still on the hunt!
Reply #4January 03, 2017, 01:08:58 pm
  • 2932
« Reply #4 on: January 03, 2017, 01:08:58 pm »
MK2 uses the same bracket, crank pully and alternator for the non-AC conversion.
Oh yeah, and it uses the same AC belt to run the alternator, ha.
Just needs a new pully and some alt brackets from a gasser.
I think the AC delete post is in the FAQs.
« Last Edit: January 03, 2017, 01:11:45 pm by fatmobile »
