Author Topic: clutch selection for 1.6l diesel?  (Read 3605 times)
April 11, 2006, 05:21:42 pm
sethyboy85
  • 284
« on: April 11, 2006, 05:21:42 pm »
I am going to be dropping an eco motor in my car (hopefully next weekend) with a FN tranny and was wondering what was out there or should I stay away from or get?
I plan to make it a TD, IC it add fuel and air (15ish probably)
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #1April 11, 2006, 08:03:29 pm
hillfolk'r
  • 1532
« Reply #1 on: April 11, 2006, 08:03:29 pm »
if you upgrade to a 210mm,,,,,make sure to re-mark the  tdc mark cast in the flywheel ,,it wont/doesnt match anymore,,,,,make a piston stop,its sorta hard in a prechamber engine,,but,,,i stuffed a piece of stainless safetywire in,w/the injector out,, turn back+forth as fw. is marked,split the difference,etc,,,the  orig.mark is at least 1 inch off,,so its no big deal ya think,right now,,,,,have fun when it comes time to do a timing belt :roll: ,you will be screwed,,,,,so remark the tdc mark on those 210 mm flywheels,if used on a diesel,,,,,,i did like the centerforce dual friction in my 1.6,,,it was about 250$us
Throttle cables ftw
