Author Topic: no vacumm on injector pump  (Read 6847 times)
October 31, 2016, 08:14:48 pm
auag
« on: October 31, 2016, 08:14:48 pm »
on my 81 vw diesel caddy ...it set for about 6 months and now i have no vacumm coming from the injector pump...it wont pull any fuel from the tank...i have cleaned both fuel lines and still nothing..i put a vacumm gauge on the pump and no vacumm..any ideas on a cheap fix?
Reply #1October 31, 2016, 09:55:58 pm
Re: no vacumm on injector pump
« Reply #1 on: October 31, 2016, 09:55:58 pm »
Add a lift pump.  Run it for a while that way.  Remove the lift pump and see if it is cured.
Reply #2October 31, 2016, 10:37:06 pm
auag
« Reply #2 on: October 31, 2016, 10:37:06 pm »
thanks for the reply...any recommendations on a lift pump?
Reply #3November 01, 2016, 06:36:32 pm
« Reply #3 on: November 01, 2016, 06:36:32 pm »
Anything putting out a fairly high flow rate which you can draw fuel through when not operating will work. There are quite a few Facet Posi-Flow pumps which are suitable. Keep the pressure below 10 PSI or you may end up with leaks at the pump shaft.
Reply #4November 01, 2016, 10:38:24 pm
air-cooled or diesel
« Reply #4 on: November 01, 2016, 10:38:24 pm »
huh, cause on mine they will no longer prime theirselves, so i prime in line; pull off fuel filter, and manually prime, if needed it keeps/gets me going.
Reply #5January 03, 2017, 12:41:17 pm
  • 2932
« Reply #5 on: January 03, 2017, 12:41:17 pm »
If everything is  moving right there should be NO vacuum at the front of the pump.
Got clear fuel lines?
