General Information
General
thinking of buying AAZ swapped - 88 Cabriolet - but may have low oil pressure
Topic: thinking of buying AAZ swapped - 88 Cabriolet - but may have low oil pressure (Read 4717 times)
October 28, 2016, 10:44:10 am
SR Heer
October 28, 2016, 10:44:10 am »
I am tempted to buy an 88 Cabriolet that has had a rebuilt AAZ swapped motor 30,000 miles ago - was rebuilt with new oversize pistons and rings as well as with new stock main and rod bearings - I asked him if he had replace the intermediate shaft bearings and he did not remember so I am thinking maybe he didn't but motor does not burn or use oil - He says oil pressure at idle it shows 1 bar or 14.5 psi and then increases with RPMs.
Is 1 bar at idle low or getting to the point of being a concern?
What pressure is at the acceptable for low end readings at idle?
Is there a way a person can tell if the intermediate shaft bearings are getting close to being overly worn without taking the motor or timing belt apart?
Last Edit: October 28, 2016, 01:00:43 pm by SR Heer
97 Passat 1Z, 98 Jetta AHU, 91 Jetta AAZ TD, and 81 Rabbit Pickup
October 28, 2016, 11:52:22 am
Re: thinking of buying AAZ swapped - 88 Cabriolet - but may have low oil pressure
October 28, 2016, 11:52:22 am »
i think 1 bar is ok
October 28, 2016, 04:35:04 pm
October 28, 2016, 04:35:04 pm »
1 bar hot idle is, if anything, high oil pressure. 1 psi hot idle is low oil pressure. Maybe there is an issue with units?
October 28, 2016, 05:28:43 pm
SR Heer
October 28, 2016, 05:28:43 pm »
He said like 1 bar or 14.5psi - so that sounds about right - because when its up and running it should be around 30-40 psi - correct?
October 29, 2016, 07:47:44 am
air-cooled or diesel
October 29, 2016, 07:47:44 am »
this reading is @idle, hot,
@head
. your very healthy, 1psi isnt low, about 7psi is getting very low, and can get dangerous, although this reading is reflecting the wellness of lower end, unless you have a serious problem at head.
General Information
General
