Author Topic: Fs: blank boost android pins  (Read 3377 times)
October 19, 2016, 07:07:50 pm
Ian0391
  • 119
« on: October 19, 2016, 07:07:50 pm »
Today during my spare time at work I decided to make a couple blank boost pins so I could grind in my own taper and experiment a bit. While I was at it I milled out a few extras, I figured maybe someone on here would want some too. They're made of 305 stainless and are identical to the pin from an aaz other than a couple things. The aaz pins are 12mm diameter (.472") and these are made from half inch stock, also rather than the m6 threaded stud on top they have a threaded hole on top for an m6 bolt (I'll provide a stainless m6 bolt) which will function the exact same.
I can let them go for 20$ shipped and if you'd like more we can make a deal.
Sent from my SM-G920W8 using Tapatalk
