Author Topic: 10% gasoline mix?  (Read 8426 times)
September 17, 2016, 02:29:17 pm
westcoaster
10% gasoline mix?
« on: September 17, 2016, 02:29:17 pm »
inquiring minds and all....
I have read where the older VW diesels could take a 10% mix of gasoline in the diesel. (assuming for cold weather operation)
would the 1.9 aaz be able to do the same?
I haven't found a NEED for it yet but what circumstance or condition would it make sense to mix gasoline with the diesel fuel?
Easier cold starts?
« Last Edit: September 17, 2016, 02:31:11 pm by westcoaster »
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #1September 17, 2016, 05:22:44 pm
heywier427
  • 21
Re: 10% gasoline mix?
« Reply #1 on: September 17, 2016, 05:22:44 pm »
I mix a bit of old gas with my waste motor oil mix, but never with straight diesel.
Diesel 10,15,30 years ago was damn near oil.  Very slippery, and could be thinned out for easier starting/sheering.
Diesel now a days is almost gasoline!  It frickin evaporates.
I dont think its a good idea.
Reply #2September 17, 2016, 10:32:35 pm
« Reply #2 on: September 17, 2016, 10:32:35 pm »
Back in the days when diesel was made from dinos it was much thicker so that is why there was a recommendation to thin it out for cold weather.  These days there is no need for that.  There is more of a need to thicken it so that the IP works like it was designed to on the thicker fuel.
Just creates more pressure if thicker fuel.  Add wax or ATF and it helps.
Reply #3September 18, 2016, 11:03:06 am
srgtlord
  • 797
« Reply #3 on: September 18, 2016, 11:03:06 am »
Eventually all diesel gels and the low sulphur crapola seems to gel quicker, somewhere around 32 degrees Fahrenheit, right at the freezing point of water.
That being said I've been mixing in 2 gallons of gasoline for every 8 gallons of diesel for the past 7 years  on my 1.6D as I have had the fuel gel issue multiple times. It's much cheaper than the diesel fuel additive crapola.
Reply #4September 18, 2016, 05:00:07 pm
westcoaster
« Reply #4 on: September 18, 2016, 05:00:07 pm »
Just for winter?
What temperatures? (below freezing)
Other than keeping your fuel from gelling, any other benefits or undesired consequences?
Reply #5September 19, 2016, 06:40:10 am
« Reply #5 on: September 19, 2016, 06:40:10 am »
it makes starting easier, you can also add kerosene for this, but if you add too much of either it will knock a lot.
Reply #6September 19, 2016, 06:42:18 pm
« Reply #6 on: September 19, 2016, 06:42:18 pm »
sgtlord is running at the top end of the mix 20%  I would start with 1.5 gallons in the 10 gallon tank.  Mix it outside in a 5 gallon jug and pour it in.
Reply #7September 25, 2016, 09:55:22 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #7 on: September 25, 2016, 09:55:22 pm »
Having worked in the logging business for around 30 years now I can tell you a ton of horror stories about trying to get diesel engines to run in cold weather. I will, however, dispense with that and simply tell you that when we run into gelling problems and have to cut our fuel, we use stove oil. I can't say that I know the exact composition of it, but that's what they give us down at the bulk plant when we tell them we're having trouble with gelling.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #8September 26, 2016, 07:28:25 pm
« Reply #8 on: September 26, 2016, 07:28:25 pm »
Stove oil?   As in denatured alcohol?  Hmm not sure I have heard that one.  Going for a google search on stove oil.
Edits and interesting tiddy bits;
Off road Diesel #2 and Home Heating Oil / Fuel Oil # 2 apparently differ only in the tax applied at the time of sale.
Both are dyed red. They differ from standard Road Diesel #2 in that road tax has been applied, no red dye has been added, and there is a specification regarding ash and/or sulphur content. In extremely cold climates, Standard Road Diesel #2 may be blended with Diesel #1 or Kerosene K-1 to assist with gelling problems resulting from the cold weather. Similar blending may occur on home heating oil / fuel oil based on your geographic region, anticipated temperatures, and overall climate.
Home Heating Oil / Fuel Oil #4 and Home Heating Oil / Fuel Oil #6 have a higher BTU content. This is normally accomplished by adding much heavier petroleum oil distillate similar to automotive motor oil to the formulation. This allows a furnace to burn less fuel, for each BTU of heat produced, as well as often times reducing the cost per gallon of fuel.   These types of Home Heating Oil / Fuel Oil should NOT be used in a Diesel Fueled Engine or Generator.
... not exactly sure what you mean by "stove oil" or "furnace oil", but it sounds like what we call kerosene & diesel (or fuel oil) here.
Back when I lived in a mobile home I burned kerosene in the oil burner. It was because the tank was outside and regular fuel oil would jell in the cold weather, and the kerosene wouldn't. That may be why you were told to burn the lighter grade oil. Kerosene may be more expensive, but a tank full of the jelled cheaper fuel oil isn't worth anything when it's cold and the burner won't run.
Hmmmm I was told buy my distributor, #2 fuel IS ULSD cut with kerosine to ensure cold weather performance........stove oil.
Oh, there is a lot of keyboard noise made over this topic..... Do a search on #2 fuel or ULSD.
Main difference is price due to different taxable uses and such. Sometimes die color varies also adding to the questions
« Last Edit: September 26, 2016, 07:43:12 pm by ORCoaster »
Reply #9September 26, 2016, 10:29:55 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #9 on: September 26, 2016, 10:29:55 pm »
Good research ORCoaster. Like I said before I don't really know what it is, I just know that's what they give us. We go in, say we're gelling, and they say we'll get you some stove oil. The key thing I guess is that it works. Maybe the nomenclature differs a little from place to place, but that's what they call it here. From your research it sounds like a guy could just by-pass that step and cut your fuel with kerosene. I can't say I've ever heard of anyone cutting their fuel with gasoline.
            1984 F-250
            1999 Ford Ranger
84 Rabbit
70 Bug
Reply #10September 27, 2016, 01:27:38 pm
« Reply #10 on: September 27, 2016, 01:27:38 pm »
I am not 100% sure of the words but VW in the owners manual for the diesels mentions cutting the diesel with 2 gallons per 10 in the winter.  Not sure if they said gas or kerosene.  Might look in the Bentley too.  Front of that has some general care tips like oil this and check that.
Reply #11October 04, 2016, 01:20:08 am
sokiu
  • 1
    • Malaysia online casino
« Reply #11 on: October 04, 2016, 01:20:08 am »
Reply #12October 04, 2016, 07:12:24 pm
westcoaster
« Reply #12 on: October 04, 2016, 07:12:24 pm »
Perhaps it isn't as regular winter routine.
However when a fella is sitting miles from nowhere on a tank of diesel of questionable temperature range with the mercury falling fast, it doesn't matter if it's a good idea or not.
All that matters at that point is "the bush fix" that will pack me out of there in a reliable manor.
Your right, with a bit of forward planning a fella should have a can of antigel on hand, but that doesn't always happen... If tipping a couple liters of 50:1 chainsaw gas or straight generator gas into a 40L tank accomplishes the same thing and gets me out without catastrophic engine failure, why wouldn't I do it?
But if all I'll make it is 2Km down the road before it piles up in the ditch, then I had better pass....
« Last Edit: October 04, 2016, 07:15:52 pm by westcoaster »
Reply #13October 05, 2016, 09:33:47 am
air-cooled or diesel
« Reply #13 on: October 05, 2016, 09:33:47 am »
it was normal in the 70s to the 80s in well-below-freezing days, and esp nights to add enough gas for an anti-gel, but not enough to dilute diesel where it would other than wearing the inj pump, it would of course you know predetonate. in a pinch in can be a smart alternative, and keep you running, where otherwise your fuel would gel, getting you stuck, on a cold day. iirc it was 10% gas to a full tank, which is about 1 gal to a full tank, this is for the coldest days, and not all of us going a few miles south (and more)will see that cold, but a lesser mix is acceptable. anti-gel preferred. but on a really cold-below-freezing day(night), some gas before filling up, w/anti-gel can get you started up in the early morning.
Reply #14October 06, 2016, 01:24:25 am
« Reply #14 on: October 06, 2016, 01:24:25 am »
Fuel today has little to do with fuel from the '80s or even '90s. It is a much more refined product - the sulphur removal process is a whole other level of processing that old fuel never had. New fuel is much less likely to gel up on you; if you want to see what it'll do then follow Hagar's advice and toss a Mason jar of the fuel you're using in the freezer. If it gels up you know you need an additive. If not, you know you're good to go down to the temperature of your freezer.
