Author Topic: Aab in a mk2?  (Read 3929 times)
August 24, 2016, 06:01:59 pm
Ian0391
  • 119
Aab in a mk2?
« on: August 24, 2016, 06:01:59 pm »
Hey guys, I recently stumbled upon a guy willing to trade an aab 2.4 td 5 cylinder diesel for some yard work haha. I've been trying to find info about this motor but there's hardly any information on it. Am I right assuming it's an aaz with one extra cylinder? It would be pretty cool to try and swap this into my mk2. I realize I would probably have to notch the frame to fit it width wise but I'm hoping it would bolt to a mk2 trans. Maybe if it's not to much wider I could widen one Axle and shorten the other and shift the whole things to the side. Anybody know anything about this motor?
Sent from my SM-G920W8 using Tapatalk
Reply #1August 24, 2016, 07:56:40 pm
Re: Aab in a mk2?
« Reply #1 on: August 24, 2016, 07:56:40 pm »
Don't those fit lengthwise in the engine bay?
Reply #2August 24, 2016, 08:20:14 pm
Ian0391
  • 119
Re: Aab in a mk2?
« Reply #2 on: August 24, 2016, 08:20:14 pm »
The 5 cylinders in Audi's did but in the eurovan they are transverse, they also came with vr6s
Reply #3August 24, 2016, 09:13:15 pm
Re: Aab in a mk2?
« Reply #3 on: August 24, 2016, 09:13:15 pm »
The 5-cyl engines have a different bolt pattern than the 4-cyl.  The Mk2 trans does not have the bolt pattern for the 5-cylinder engine.
Reply #4August 25, 2016, 03:13:34 am
Ian0391
  • 119
Re: Aab in a mk2?
« Reply #4 on: August 25, 2016, 03:13:34 am »
Oh that's to bad, do you know what trans the use? I've found some threads about people swapping in aaz's instead of the gas eurovan but I guess they use a different trans that  the diesel.
Reply #5August 25, 2016, 04:31:00 am
  • 5104
Re: Aab in a mk2?
« Reply #5 on: August 25, 2016, 04:31:00 am »
it might be possible, people swap the newer 2.5l 5 cylinder in to mk2 and mk3 cars, but i know the bellhousing is different from a 4 cylinder, and i don't know if the new 2.5 has the same bolt pattern as the old 5 cylinders.  the first 2.5l swap in to a mk1 used an 020, but something was modded with the bell housing
Reply #6August 25, 2016, 05:02:51 am
Ian0391
  • 119
Re: Aab in a mk2?
« Reply #6 on: August 25, 2016, 05:02:51 am »
Hmm, maybe I'll have to bite the bullet and grab that engine so I can start experimenting
Reply #7August 25, 2016, 06:11:50 am
  • 5104
Re: Aab in a mk2?
« Reply #7 on: August 25, 2016, 06:11:50 am »
looks like the newer vw 2.5 has a 5 cylinder bolt pattern from what i found online, still it could be possible with an adapter plate and lots of custom working haha.  probably have to figure out a different oil pump and pan though to put it in to a transverse bay
Reply #8August 25, 2016, 06:18:30 am
Ian0391
  • 119
Re: Aab in a mk2?
« Reply #8 on: August 25, 2016, 06:18:30 am »
I'm positive the motor is already transverse in the eurovan, I wonder how much wider it is though
Reply #9August 25, 2016, 08:13:43 am
Re: Aab in a mk2?
« Reply #9 on: August 25, 2016, 08:13:43 am »
The eurovan trans has the bell housing bolt pattern for BOTH 4-cyl and 5-cyl.  I do not believe a eurovan trans will fit into a mk2 without a lot of custom work.
IMO, trying to fit that engine into a Mk2 would be a lot of Buck for very little Bang.  You'd be better off selling it and purchasing an AHU for a bolt-in install that actually fit in the engine compartment and at the same time gave you better performance and better fuel economy.
« Last Edit: August 25, 2016, 08:17:38 am by libbydiesel »
Reply #10August 25, 2016, 08:36:02 am
Ian0391
  • 119
Re: Aab in a mk2?
« Reply #10 on: August 25, 2016, 08:36:02 am »
So the trans bolts to both but the motor bolts to only a 5 cylinder trans? I'm not really looking for the best motor I cam use, just something fun to try out. I already have a compound turbo aaz in there, I just thought 5 cylinders might be fun. I was hoping it would bolt to my built 010 but I guess it wouldn't.
Reply #11August 25, 2016, 08:40:46 am
  • 5104
Re: Aab in a mk2?
« Reply #11 on: August 25, 2016, 08:40:46 am »
i agree with libby, but it would be really interesting if you could do it
Reply #12August 25, 2016, 10:02:37 am
  • 5104
Re: Aab in a mk2?
« Reply #12 on: August 25, 2016, 10:02:37 am »
actually the eurovan 5 cylinder transmissions look an awful lot like an 02a, you may be able to do some swapping of output flanges and shift towers and make it work like that.
Reply #13August 25, 2016, 11:03:03 am
Ian0391
  • 119
Re: Aab in a mk2?
« Reply #13 on: August 25, 2016, 11:03:03 am »
Is the part where the clutch bolts to the crank the same on 4/5/6 cylinder engines?
Reply #14August 27, 2016, 05:40:40 pm
Ian0391
  • 119
Re: Aab in a mk2?
« Reply #14 on: August 27, 2016, 05:40:40 pm »
Anyone know?
