Author Topic: 1986 Golf alternator tensioner pulley parts-with AC  (Read 3933 times)
July 29, 2016, 05:24:02 pm
coalminer16
  • 30
« on: July 29, 2016, 05:24:02 pm »
I need the tensioner pulley parts. I have the pulley and the bolt it is supposed to go on but I need some parts you can't buy anymore that go between the bolt, brace and pulley. Can someone help me out. Bought the car without as a non-running car parked due to 5th gear going out of it. It runs and timing belt has been changed and soon the tranny. Just need these parts.
Reply #1August 03, 2016, 01:10:07 pm
Jettagli16v
  • 344
Re: 1986 Golf alternator tensioner pulley parts-with AC
« Reply #1 on: August 03, 2016, 01:10:07 pm »
I should have those parts leftover.
I have the bracket, and the long screw, and the eye bolt that the screw goes into to tension the alt belt.
I also have a new pulley with a bearing I replaced, as the old bearing was bad, and I think they are hard to find.
If you want to post a picture of what you have, I can confirm for sure that I have what you need.
Just drop me an email at Black34Boxster at gmail. (in case I don't sign in here for a few weeks)
Thanks!
-Brad
Reply #2August 13, 2016, 05:47:39 pm
coalminer16
  • 30
« Reply #2 on: August 13, 2016, 05:47:39 pm »
Thank you for the parts. Working on swapping a tranny out now on it.
Reply #3September 26, 2016, 10:53:29 pm
Rattlebox
  • 12
« Reply #3 on: September 26, 2016, 10:53:29 pm »
I have the Alternator tensioner pulley bearings for sale. $20 shipped.
85 Jetta 1.6d Wolfsburg.
Will perform some Mk1/2 diesel services in the NE Ga/Upstate SC and WNC areas. Timing belts and accessories, IP timing, Injector installs, mechanical lifter valve adjustments.
