Author Topic: FS: MI - Complete 1.6 Diesel and 5 speed trans swap with everything!!  (Read 4339 times)
July 28, 2016, 11:38:10 am
ultimagtr
  • 6
Hello,
I would like to sell my complete 1.6L NA Diesel engine. Engine code: ME
it came out of my 91 Jetta coupe and has 190,000 miles. The engine runs great and always starts first try. I have changed the oil every 3K miles with Synthetic Rotella T6 oil and have always used Stanadyne additive every fill-up as did the previous owner.
It does have a few drips from the oil pan and the valve cover but that's about it. It does not smoke excessively and was super reliable.
The engine is complete and I mean everything comes with it: Injection pump, PS pump, AC compressor, air box, everything to make it just drop in and go. The timing belt was done at 155,000 miles as was the water pump.
I also have the 5 speed trans that came with the engine. Trans Code: AWY.
Trans shifts fine and I am including everything from the shifter tower to the half shafts, manual clutch cable to the pedal cluster if needed. Clutch was also done at 155,000 with the engine timing belt.
Here is all the maintenance that was done at 155,000:
-timing belt
-accessory belts
-glow plugs
-alternator
-clutch and pressure plate, upgraded to 9 bolt flywheel
-gear oil change with Mobil 1 synthetic
-coolant flush
-thermostat
I will post pics but there is nothing out of the ordinary with this engine and trans it ran perfectly fine when I pulled it.
If you are local (Detroit Area) and you buy this thing and install it, I will guarantee it will run and drive with no issue or I will give you all of your money back! This is in writing so no going back :o)
The only reason I pulled them out of my car is because I swapped over to an ALH and 02J trans.
I would prefer to sell all together but I will separate.
Engine: $350
Trans: $350
Together: $600
Also, due to the size I would prefer not to ship, so buyer has to pick them up. I have a cherry picker.
Reply #1July 29, 2016, 08:22:56 am
Is that a TD pump or an eco pump?
Reply #2August 08, 2016, 05:04:57 am
ultimagtr
  • 6
Re: FS: MI - Complete 1.6 Diesel and 5 speed trans swap with everything!!
« Reply #2 on: August 08, 2016, 05:04:57 am »
Neither, it is an NA engine so I believe it was a DI.
Reply #3August 08, 2016, 08:03:58 am
ultimagtr
  • 6
« Reply #3 on: August 08, 2016, 08:03:58 am »
so after a little more digging, this is not the original pump I'll have to get back to you with what pump I have
Reply #4August 08, 2016, 11:45:12 am
« Reply #4 on: August 08, 2016, 11:45:12 am »
The '91 would have the altitude compensating pump.  That looks correct.
Reply #5August 09, 2016, 07:21:52 am
ultimagtr
  • 6
« Reply #5 on: August 09, 2016, 07:21:52 am »
Thank you for the reply. Someone on TDI club also stated the same thing. I will look for a PN on the pump and post it.
The engine ran like a top before the pull....all be it like a little top :) but it ran fine so I would think the the pump was right for the engine.
