Author Topic: Lime Green advance spring part # Lets find a replacement!  (Read 2418 times)
July 13, 2016, 08:37:19 pm
heywier427
  • 21
« on: July 13, 2016, 08:37:19 pm »
Does anyone have a lime green spring, or the part #, or anything close.
I thought I had one, but I cannot find it!!!!
Any ideas on where to point me to start looking for a replacement company?
Thanks.
Reply #1July 13, 2016, 09:17:19 pm
heywier427
  • 21
Re: Lime Green advance spring part # Lets find a replacement!
« Reply #1 on: July 13, 2016, 09:17:19 pm »
Seems like the correct part #s are
Bosch  464 619 322
Vw 068 130 677 F
Iveco 7984593
Reply #2July 16, 2016, 07:49:46 am
sgnimj96
  • 185
« Reply #2 on: July 16, 2016, 07:49:46 am »
 If you want more advance,   fuel pressure-  makes a huge difference
You gotta make a gauge that taps into the internal pressure of the pump,
 something like-
     43.5 Psi at 1000 RPM
    2000 Rpm -about 75.4 Psi
I read in a post somewhere that these old pumps may have softened springs already from use;
I had to put several of the spring shims back in after adjusting my 1.6na fuel pressure.   Static timing was good for starting,  but when I revved it  would rattle from too much advance.
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
Reply #3July 18, 2016, 03:59:41 pm
  • 2932
« Reply #3 on: July 18, 2016, 03:59:41 pm »
 Playing with the shims can help.
 Isn't the green spring from a 1.5 pump? 107A?
 Check a bosch service center with a 1.5 part number.
