Author Topic: Intake Air Temperature sensor  (Read 2022 times)
July 05, 2016, 06:25:26 am
gto
  • 3
« on: July 05, 2016, 06:25:26 am »
Hello,
I own a european Golf 3 (1992) GTD with AAZ engine.
The previous owner  made some mods about engine and suspensions (he replaced turbo with a vnt-15, added an intercooler from astra CDTI and lowered the machine)
I then buyed an AAZ engine with less mileage and swapped it (because the original one had some trouble) making a mix of parts (actually it did all my mechanic) because "new" IP was with electronic so I keeped the "old" pump.
I managed to restore the originality of the engine so the turbo is now KKK03 but I wanted to keep the intercooler so I buyed from the scrapyard piping from a golf 3 with engine 1z and intercooler from another golf 3 TDI.
It seems to me that all is working good.
I noticed on one of the intercooler pipe the presence of an Intake Air Temperature sensor, obviously it is attached to nothing because AAZ has not got an ECU, but I was wondering if it's possible to use this sensor maybe attaching it to some gauge?
Did someone already tried to do this?
Leonardo
Reply #1July 05, 2016, 07:03:16 am
Re: Intake Air Temperature sensor
« Reply #1 on: July 05, 2016, 07:03:16 am »
i've been curious about this same thing for a later build, itd be a great tool for tuning intake location, intercooler placement, and knowing when a turbo compressor has become inefficient.  they definitely make intake air temperature gauges, but its hard to say if it will work with the tdi sensor.
Reply #2July 12, 2016, 05:44:27 pm
« Reply #2 on: July 12, 2016, 05:44:27 pm »
You should be able to use an Auber Instruments or similar type electronic gauge with that sensor. It'll take a bit of work to decipher the curve it needs though.
