Author Topic: FS TD conversion kit 1.6/1.9 and misc TD parts and gauges  (Read 5269 times)
June 08, 2016, 01:49:50 pm
« on: June 08, 2016, 01:49:50 pm »
Clearing out the shed, I think this is the last of it! Click pictures for full size. If you want more pictures just ask.
Turbo diesel conversion kit: $300 SOLD It's obviously missing some pieces but it's the bulk of what you need. This K03 would be perfect for someone looking to just add a bit more power without bothering to upgrade to a TD pump. Fast spool up so there should be minimal or no smoke. It will do fine (better) if you have a TD pump though. Turbo has some shaft play but it's in good, usable shape.
Includes:
1.6 OR 1.9 TD intake manifold
AAZ K03 exhaust manifold
AAZ K03 with drain line
1.6 or 1.9 TD oil feed line. Or I have a custom flexible feed line for an extra $10
MK2 Rear mount
K03 intake hose
K03 boost hose
3x Turbo bolts
Misc pieces
AAZ intake manifold - $60
1.9 oil feed lines - $20 each
k03 boost hose - $10
1.6 intake hose - $25
cut off from turbo drain hose - $5 SOLD
Unused FM100 fuel filter assembly $50
MK2 cold start cable - $15
Solid lifter shim kit with bucket depressor - $80 SOLD
1.6 vacuum pump $30
Cut off AAZ downpipe - T3, K24, K14, T2 - $20
Gauges
Boost - $NLA
Oil - 10
Temp - $10
Fuel - $10
Oil pressure sending unit - $5
Temp sender - $15
« Last Edit: July 15, 2016, 10:23:01 am by burn_your_money »
Reply #1June 30, 2016, 05:32:34 am
Re: FS TD conversion kit 1.6/1.9 and misc TD parts and gauges
« Reply #1 on: June 30, 2016, 05:32:34 am »
Up
Reply #2July 11, 2016, 10:32:13 pm
vwzzuk
  • 88
    • http://www.acmeadapters.com
« Reply #2 on: July 11, 2016, 10:32:13 pm »
Is this still available?
81 Rabbit Pickup, 1.9NA
85 Suburu Brat, 1.9TD AAZ
87 Suzuki Samurai, 1.6TD
92 Sidekick 4dr, 1.9TDI
Reply #3July 15, 2016, 10:23:35 am
« Reply #3 on: July 15, 2016, 10:23:35 am »
Kit just sold along with a few other items. Ad accurately reflects what I have left.
