Author Topic: 1.6 na block CS  (Read 3724 times)
March 20, 2016, 08:29:35 am
Bravo2043
  • 27
1.6 na block CS
« on: March 20, 2016, 08:29:35 am »
Confession time, I pulled the head off the CS engine in my bus thinking I was changing the head gasket. The head was cracked in 6 places. It looks like it got real hot, then parked. Eventually someone made it run again, it was running great before I pulled the head. The head is junk and I could see the block would need to be bored to get it to quit using oil.
The block sat all winter in my garage with the head off it. I sprayed it with wd40, but the bores rusted anyway.
After I pulled the engine and stripped oil pan water pump and IP I threw the block in the yard. My plan WAS to scrap it. Rumor had it someone might want it. That was last week.
Come get it, I'll make you a hell of a deal. Otherwise its going in the trunk of the doner cars trunk when I scrap it. IM me if interested.
Reply #1March 20, 2016, 08:40:50 am
Bravo2043
  • 27
Re: 1.6 na block CS
« Reply #1 on: March 20, 2016, 08:40:50 am »
Its in Holland Michigan 49424
