General Information
General
1991 jetta eco diesel shaking bad
Pages:
Topic: 1991 jetta eco diesel shaking bad (Read 18133 times)
Reply #15
April 05, 2016, 08:48:13 am
derrickd95
User+
Re: 1991 jetta eco diesel shaking bad
Reply #15 on:
April 05, 2016, 08:48:13 am »
Yeah it has a Bosch now, so the batt was 12.5 and running it was 13.9. Can't find a battery ground cable locally that's stock so I'm making a heavy duty one
Reply #16
April 05, 2016, 08:58:58 am
air-cooled or diesel
Reply #16 on:
April 05, 2016, 08:58:58 am »
no napa store near you? even advanced or auto zone should carry, them,. a 13.9 reading is pretty weak for a bosch alt, its possible to refresh it, but not that a refresh of a new voltregulator and a clean up will get it working better for longer,. my alt(s) right now i picked up are bosch alts, rebuilt by remey, they put out 14.3x volts, at full batt charge, (thats fresh of course).
Reply #17
April 05, 2016, 09:44:11 am
derrickd95
User+
Reply #17 on:
April 05, 2016, 09:44:11 am »
I will build some new grounds. The battery 12.5 at rest and 13.9 while running I think it's all the grounds. Even though I cleaned them it's still the old copper braided wire.
Reply #18
April 05, 2016, 10:06:48 am
Reply #18 on:
April 05, 2016, 10:06:48 am »
new grounds, and/or battery straps, are cheap investments for reliability. adding new grounds, esp the motor ground (to body), also pay off well, i added new hot charging wire too. clean stuff up. you can also check your voltage drop when you finish cleaning stuff up, theres a link somewhere in faq.
Reply #19
April 05, 2016, 10:24:15 am
derrickd95
User+
Reply #19 on:
April 05, 2016, 10:24:15 am »
It seems to start after a longer drive and reaching operating temp
Reply #20
April 05, 2016, 11:21:45 am
Reply #20 on:
April 05, 2016, 11:21:45 am »
still? its a non-a/c car rite?
Reply #21
April 05, 2016, 04:22:18 pm
Reply #21 on:
April 05, 2016, 04:22:18 pm »
Sounds like you got a handyman special. You're gonna need a Bentley Manual.
While the engine is running poorly, you can slightly loosen each injector fitting in sequence, to see if there is one that makes no difference... at least you could narrow to one cylinder.
Possible you have a bad valve/lifter, or bad injector. Maybe as simple as a missing injector heatshield. More rare would be something funky in one port of the IP.
I'd suggest getting the Bentley manual, putting clear lines in and out of the IP, getting an older style fuel filter that has no plastic tee pre-warmer and get some vw diesel timing tools.
I concur that if you experience excessive torque-steer, the control arm bushings are bad... the loaded arms are cheap enough to R&R without pressing the bushings in.
Reply #22
April 05, 2016, 05:02:06 pm
derrickd95
User+
Reply #22 on:
April 05, 2016, 05:02:06 pm »
It ran absolutely fine in the morning after I charge the battery I think the drive going into my work which is about 30 miles out with the heater on the lights on and the fan working I think drain the battery down a little bit plus I didn't get the normal squeal I normally get from the alternator when the battery is fully charged and these things didn't start until the belt broke and I drove back from work. I'm really leaning towards alternator so I ordered a new alternator. I'm going to replace all the grounds with new cables
Reply #23
April 05, 2016, 05:02:59 pm
derrickd95
User+
Reply #23 on:
April 05, 2016, 05:02:59 pm »
I also have a Bentley manual the time engage dial and I also have four new injectors but there for 130 bar not 155 bar
Reply #24
April 05, 2016, 05:03:57 pm
derrickd95
User+
Reply #24 on:
April 05, 2016, 05:03:57 pm »
I forgot to mention it is a power steering with air-conditioning engine I have also replaced both front control arms
Reply #25
April 06, 2016, 07:22:26 am
derrickd95
User+
Reply #25 on:
April 06, 2016, 07:22:26 am »
Last night I ran a 14 gauge ground from the top bolt on the alternator straight to the negative post on the battery and I ran another wire to the body. It was at 13.9-13.6 volts. Full load with lights and heater on its at 13.5-13.6. Like I said it runs decent when cold but when it's warm after a extended drive it shakes and shakes violently when I turn the wheels. It goes away if I drive with the cold start on. Comes back when I push the cold start back in. Squeals everytime I start it for about 40 seconds and it didn't start doing this until after the alternator belt broke and I had to drive 50 miles with no alt
Reply #26
April 06, 2016, 07:32:24 pm
derrickd95
User+
Reply #26 on:
April 06, 2016, 07:32:24 pm »
Replaced the fuel filter. Bubbles in the lines during idle and get bigger when I rev. I cracked all the injectors and the all effected the engine Rpm's and made it run rough. So it lookalike in cutting some hoses down to redo connections and blow some compressed air down the lines
Reply #27
April 06, 2016, 07:35:35 pm
Reply #27 on:
April 06, 2016, 07:35:35 pm »
Sounds like a good plan. Not uncommon to have vacuum building up in the supply line if it is restricted.
Reply #28
April 08, 2016, 01:21:01 pm
mtrans
Reply #28 on:
April 08, 2016, 01:21:01 pm »
Quote from: derrickd95 on April 06, 2016, 07:32:24 pm
In feed or return line,try to fid IP with jar.
I`ll improve my English
Reply #29
April 08, 2016, 01:44:58 pm
derrickd95
User+
Reply #29 on:
April 08, 2016, 01:44:58 pm »
Feed line, also belt for alt is too big come to find out so I know that's causing issues
Pages:
General Information
General
