Author Topic: aaz fuel pump braket  (Read 3915 times)
March 18, 2016, 06:02:05 am
moldovadizel
  • 5
« on: March 18, 2016, 06:02:05 am »
hi fellas
having this issue stock pump crapped out, have this previously used giles pump I had on another motor and was swaping this over but it does not fit the braket  is different.
how do I go about this fellas? do I need to get a different braket and swap over, is that possible at all or different pump is a must? :(
Reply #1March 18, 2016, 11:46:33 am
Re: aaz fuel pump braket
« Reply #1 on: March 18, 2016, 11:46:33 am »
yeah looks like the pump on the left is the later adjustable pulley style, pump on the right is mid style where the pump adjusts in the bracket.  you just need to use the bracket that matches the pump, and you should be on your merry way
Reply #2March 18, 2016, 06:41:59 pm
RunninWild
  • 609
« Reply #2 on: March 18, 2016, 06:41:59 pm »
Might want to confirm this but I believe the 1.6td bracket is the same as the one you're looking for.
Reply #3March 18, 2016, 08:56:05 pm
« Reply #3 on: March 18, 2016, 08:56:05 pm »
1.6 and 1.9 brackets are quite different.
Reply #4March 19, 2016, 07:32:11 am
RunninWild
  • 609
« Reply #4 on: March 19, 2016, 07:32:11 am »
Doesn't the older style aaz pump use the same bracket as the 1.6 though? I know the newer style that adjusts timing through the pulley is different but I was under the impression the older style was the same?
Or does the older aaz pump have a larger snout as well? If the only difference is the snout diameter he could modify it to work like I did with my aaz pump.
Actually I'm wrong the way the mount attaches to the block is completely different in 1.6 vs 1.9l blocks.
« Last Edit: March 19, 2016, 07:35:14 am by RunninWild »
Reply #5March 19, 2016, 02:13:56 pm
dontdoemyourself
  • 110
    • www.clearviewmt.com
« Reply #5 on: March 19, 2016, 02:13:56 pm »
I've got an early AAZ pump bracket if ya want it..
1982 Vanagon diesel mTDi
1982 Jetta coupe - AHU/O2A project
1977 Scirocco Champagne 1.8 RV / Digi2
1963 Microbus Panel camper
05 Audi Allroad 6spd
01 Toyota Tundra V6 5VZFE/ 5 speed
Reply #6March 19, 2016, 08:40:34 pm
« Reply #6 on: March 19, 2016, 08:40:34 pm »
As I mentioned before the 1.6 and 1.9 brackets are quite different.  The 1.6 brackets are 2-piece stamped steel.  One piece runs along the end of the block.  With the earlier metal cover, that piece incorporates the passenger side engine mount.  With the later plastic covers, it incorporates the timing cover backing plate.  The other piece bolts to the first pump bracket piece and to the block with two bolts behind the pump.  The AAZ brackets (both of them) are not stamped steel and instead are a single cast piece that bolts only to the block using three bolts.
Reply #7March 23, 2016, 03:56:11 pm
moldovadizel
  • 5
« Reply #7 on: March 23, 2016, 03:56:11 pm »
YES PM'D!
