Author Topic: that new "silicone" ive been raving about,,,  (Read 7697 times)
April 08, 2006, 10:17:09 pm
hillfolk'r
  • 1532
« on: April 08, 2006, 10:17:09 pm »
ok here it is: international part number 1 830 858 C1
ithink its around 15 bucks,,but itll last 4 ever
international RTV T442 RTV SILICONE RUBBER,international,,,,as in trucks to be clearfile:///C:/Documents%20and%20Settings/user/My%20Documents/My%20Pictures/2006-02%20(Feb)/HPIM0075.JPG
Throttle cables ftw
Reply #1April 09, 2006, 07:00:05 am
wyldman
  • Authorized Vendor
  • 403
« Reply #1 on: April 09, 2006, 07:00:05 am »
Use Permatex "the right stuff".It's probably the same stuff as the International stuff.Best sealant there is.
Auto Proformance Services - VW Diesel parts and service
(416)565-7282
Reply #2April 09, 2006, 08:53:01 am
hillfolk'r
  • 1532
« Reply #2 on: April 09, 2006, 08:53:01 am »
its thick and grey,,best toput a small dab on a part,and smooth it out with your finger,,its what international seals their oil pans with on the power strokes,they have no gasket,,,seems more  like harder rubber than normal silicone,,,all i know is,,its wicked stuff,,,everyone iknow who removes a power stroke pan,,,better get out a hammer and straighten the pan rail back out,,its got a wicked bond,,its nice to hold the valve cover gasket in the corners for the "red worm",,,,,,the tube says some crazy stuff like its a thixothropic ? sealant ,,ill look that up later,,,, :D
Throttle cables ftw
Reply #3April 09, 2006, 09:00:14 am
hillfolk'r
  • 1532
« Reply #3 on: April 09, 2006, 09:00:14 am »
ohyea,,heres another one thats good,,did ya know locktite can be corrosive to the fastners????heres a good substitiue,has about the same strength as the blue locktite,,,,use 3m weatherstrip adhesive!!,,it has about the same strength as the locktite,with no fastner damage,,,,,heck i love this stuff,,use it all the time,,,,glue nuts into sockets,soi can get in a tight area,with the  nut in the socket,,,,put on a dab on a nut,,assemble in socket ,,pull it slightly apart,,blow on it to dry it,,stick it back together,,,heck,, the other day iused it to hold a patch panel in place before i welded it,,i needed a 3rd hand,thats this stuff,,,,,when i put on my duckbill spoiler,,all i had was plainmetric bolts and nuts,,,,,,how do you tighten them up,so it didnt crush the spoiler,yet hold it in place tight enough so hardware didnt rattle off??really needed nylock lock nuts,,but a dab on threads,,and nut,,voila,,instant locknut!!!,,plus itll glue all kinds of materials together,,,,coat both sides,and let dry,like contact cement,,one of my favorite chemicals in the shop,,,,,,,atwork,iprobably go thru about a tube a month or so,,,
Throttle cables ftw
Reply #4April 11, 2006, 05:45:26 am
« Reply #4 on: April 11, 2006, 05:45:26 am »
Quote from: "hillfolk'r"
its thick and grey,,best toput a small dab on a part,and smooth it out with your finger,,its what international seals their oil pans with on the power strokes,they have no gasket...
VW part: D 176 404 A2  They use it on all of the aluminum pans in place of a gasket, MK4 cars and newer.  It's the toughest stuff I've used.  :)
84 Scirocco 8v
00 Camaro L36 M49
Reply #5April 12, 2006, 01:20:01 pm
fspGTD
  • 1529
    • http://home.comcast.net/~vwgtd
« Reply #5 on: April 12, 2006, 01:20:01 pm »
Moved to general section.  I appreciate the contribution, however this doesn't seem to be frequently asked question section worthy to me.
Jake Russell
Dieselicious Turbocharger Upgrade/Rebuild Kits
Reply #6April 12, 2006, 08:40:25 pm
hillfolk'r
  • 1532
« Reply #6 on: April 12, 2006, 08:40:25 pm »
thas' cool :D ,,like i really get exited about rtv,,,wow,,thats a scary thought,,,its like ihad an out loud thought,,i didnt wanna post it in the middle of another thread,,,kill this one jake if need be :D
Throttle cables ftw
