Author Topic: AAZ hard to start when cold All glow plugs good  (Read 4124 times)
January 13, 2016, 11:56:47 pm
vixentd
  • 88
« on: January 13, 2016, 11:56:47 pm »
Factory crate motor with the D crank about 100000 kms ago.  Go to 24 degrees Fahrenheit and is very hard to start. When glowed the plugs 4 or 5 times it then started and seemed to run on 2 cylinders for a few seconds.
I have.
1.  Check he ohms on the glowplugs.  And just to make sure removed all the glow plugs and they heat up on the battery.
Any chance it could be
1.  Injectors ?  Car runs fine once started.
2.  Timing has gone out?  Haven't checked it yet?
never Come across this before.
Reply #1January 14, 2016, 08:52:40 pm
Re: AAZ hard to start when cold All glow plugs good
« Reply #1 on: January 14, 2016, 08:52:40 pm »
If it runs fine after just a bit but is hard to start I would be looking for an air leak on the pump or the lines to it.  Sounds to me that a  the glows are doing as they should.  Front seal good or leaking?  Remember a vacuum will leak sooner than a pressure leak.
