For Sale/Looking For
Parts for Sale/Wanted
Wanted MK2 spindles
Topic: Wanted MK2 spindles (Read 4137 times)
January 09, 2016, 03:12:34 pm
butch2000
User+
Wanted MK2 spindles
January 09, 2016, 03:12:34 pm »
Doing a AAZ into 1981 Caddy , looking for a pair of MK2 spindle so the axles will work ? thanks
January 10, 2016, 12:11:44 pm
Re: Wanted MK2 spindles
January 10, 2016, 12:11:44 pm »
I'm guessing you are using the AAZ transmission?
I think most people either swap the axle flanges on the transmission or swap the inner CV joints. You can buy mk1 100mm axles as well.
January 10, 2016, 12:17:54 pm
dontdoemyourself
January 10, 2016, 12:17:54 pm »
You will need scirocco 16v spindles or 87+ cabriolet ones
1982 Vanagon diesel mTDi
1982 Jetta coupe - AHU/O2A project
1977 Scirocco Champagne 1.8 RV / Digi2
1963 Microbus Panel camper
05 Audi Allroad 6spd
01 Toyota Tundra V6 5VZFE/ 5 speed
January 25, 2016, 01:03:53 pm
butch2000
User+
January 25, 2016, 01:03:53 pm »
burn money thanks , I did not know that ,
February 07, 2016, 08:07:05 pm
February 07, 2016, 08:07:05 pm »
There is a way to put the later MK2 spindles, with the bigger bearing and ball joint into a MK1.
You'd have to do some research on the vortex.
Wanted MK2 spindles
