Author Topic: AAZ pump on TDI  (Read 10752 times)
November 22, 2015, 03:07:16 pm
RyanJames170
  • 4
AAZ pump on TDI
« on: November 22, 2015, 03:07:16 pm »
If a person put a AAZ pump on a AHU tdi.. how far could they push the pump as far as torque output? If I wanted more Power, what would I have to do as far as swapping out parts to make more along the lines of 230lbs of torque?
I am doing reserch, into doing a MTDI and what pumps I can use..
Reply #1November 22, 2015, 11:08:51 pm
Re: AAZ pump on TDI
« Reply #1 on: November 22, 2015, 11:08:51 pm »
It will be a laaaame weak engine with an AAZ pump.  The AAZ pump has a smaller pump head than a TDI and won't even come close to stock TDI power.
You'd be MUCH better off using a Land Rover 200TDI or 300TDI pump.  They bolt on with a little work, have an 11mm head (which is the "big" size for TDIs) and already have a suitable advance curve to run a TDI.  Getting 230 ft-lbs will be reasonably easy with that pump, provided you have the other supporting mods you need (turbo/injectors).
Reply #2November 23, 2015, 12:54:14 pm
RyanJames170
  • 4
Re: AAZ pump on TDI
« Reply #2 on: November 23, 2015, 12:54:14 pm »
so there is not way to turn the AAZ pump up or mod it easly to make that kind of power?
Reply #3November 24, 2015, 07:02:18 am
  • 5104
Re: AAZ pump on TDI
« Reply #3 on: November 24, 2015, 07:02:18 am »
no its not designed for direct injection it can not create enough injection pressure to properly run a tdi.
Reply #4November 25, 2015, 09:26:08 am
Re: AAZ pump on TDI
« Reply #4 on: November 25, 2015, 09:26:08 am »
It's more a matter of fuel quantity than pressure.  Regardless, the combination of the 9mm plunger, control collar lever assembly, accel lever offset, inadequate dynamic advance, etc... all combine to make for a poor mTDI pump.
Reply #5November 28, 2015, 10:33:04 am
urmas
  • 43
Re: AAZ pump on TDI
« Reply #5 on: November 28, 2015, 10:33:04 am »
With an unmodified pump the setup will return very little power and good mpg.
'89 Mk2 AFN mTDI
Reply #6November 29, 2015, 07:38:29 pm
RyanJames170
  • 4
Re: AAZ pump on TDI
« Reply #6 on: November 29, 2015, 07:38:29 pm »
i have decited to get a pump made.. as i need to make over 200lbs of torque for the TDI to work.
Reply #7November 29, 2015, 08:03:31 pm
Re: AAZ pump on TDI
« Reply #7 on: November 29, 2015, 08:03:31 pm »
Sounds like a good plan. The Rover pumps can often be had somewhat cheaply but if you have a definite power goal and can afford a custom pump that will be a good way to go.
