Author Topic: Wtb: AAZ long block  (Read 6016 times)
November 14, 2015, 07:23:10 am
dontdoemyourself
  • 110
    • www.clearviewmt.com
Wtb: AAZ long block
« on: November 14, 2015, 07:23:10 am »
Well, long story short.. I need a new long block for. If anyone has a cylinder head or a block i will be willing to buy separately and build the engine myself. Thanks!
1982 Vanagon diesel mTDi
1982 Jetta coupe - AHU/O2A project
1977 Scirocco Champagne 1.8 RV / Digi2
1963 Microbus Panel camper
05 Audi Allroad 6spd
01 Toyota Tundra V6 5VZFE/ 5 speed
Reply #1November 15, 2015, 06:26:12 pm
dontdoemyourself
  • 110
Re: Wtb: AAZ long block
« Reply #1 on: November 15, 2015, 06:26:12 pm »
Or, a tdi and and Land Rover pump.
Reply #2November 16, 2015, 06:20:40 pm
canadacatalyst
  • 34
    • canadacatalyst
« Reply #2 on: November 16, 2015, 06:20:40 pm »
we have a few. [email protected]
many vw diesel used parts on hand
1988-2008 jetta, golf, passat, new beetle
www.canadacatalyst.ca
Reply #3November 19, 2015, 02:39:42 am
Patrick
  • 1034
« Reply #3 on: November 19, 2015, 02:39:42 am »
« Last Edit: November 19, 2015, 02:41:21 am by Patrick »
Reply #4November 19, 2015, 06:07:26 am
« Reply #4 on: November 19, 2015, 06:07:26 am »
If you want an aaz that needs rebuilt I have one in the states. You have no location, so I didn't reply until now. I am thinking of buying some things and would consider getting rid of it as is minus the IP bracket let me know if you are serious.
Reply #5November 20, 2015, 02:49:55 pm
dontdoemyourself
  • 110
« Reply #5 on: November 20, 2015, 02:49:55 pm »
Cool, I am in Montana.. How much are you asking?!
Reply #6November 20, 2015, 02:50:57 pm
dontdoemyourself
  • 110
« Reply #6 on: November 20, 2015, 02:50:57 pm »
Patrick, where are you located?
Reply #7November 22, 2015, 11:17:10 am
« Reply #7 on: November 22, 2015, 11:17:10 am »
I would take 600 plus shipping. I used fedex to ship my last aaz to Colorado, but I had to take apart as they only do 150lbs. IIRC it was around 100.00 but that was long ago.
Reply #8November 29, 2015, 07:15:45 am
dontdoemyourself
  • 110
« Reply #8 on: November 29, 2015, 07:15:45 am »
Hmm.. Mileage? Did you hear it run ever??
Reply #9November 30, 2015, 05:48:28 am
« Reply #9 on: November 30, 2015, 05:48:28 am »
No clue on mileage and I never heard it run. I would rebuild it as it is easy to do now and you know what you will have. I did take it to the machinist and had the bores measured without removing the pistons and it fell within spec of std pistons from what we could tell. It might be the block you re ring. IIRC this one had valve imprints so if I had to guess it broke a TB at one point.
Reply #10November 30, 2015, 09:08:34 pm
dontdoemyourself
  • 110
« Reply #10 on: November 30, 2015, 09:08:34 pm »
I see! I wonder if any of my pistons could be salvaged.. Was it a block and head?
Reply #11December 01, 2015, 07:05:37 am
« Reply #11 on: December 01, 2015, 07:05:37 am »
was it a block and head? Doesn't make any sense to me. I have another head to go onto it...again, I would rebuild that too. My price was for the head and short block. If you want it let me know.
Reply #12December 01, 2015, 05:57:15 pm
dontdoemyourself
  • 110
Wtb: AAZ long block
« Reply #12 on: December 01, 2015, 05:57:15 pm »
Sorry, I guess that was sort of an obvious one. Where are you located? I may be able to send a call tag through my workplace to send it freight. How bad is the head after the TB break? I was considering rebuilding mine, though if yours is rebuildable I'm pretty interested to have another as a spare. Did you have the oil pan off? If so we're the rod caps all tight? Guess it doesn't matter if I'll be rebuilding it.. TIIA
« Last Edit: December 01, 2015, 06:20:33 pm by dontdoemyourself »
Reply #13December 01, 2015, 07:40:02 pm
« Reply #13 on: December 01, 2015, 07:40:02 pm »
I have a completely different head than that was on the block...I do not have the broken TB head and do not know if the TB broke I am just assuming since there are valve prints. It looks very rebuildable. Oil pan is off and you would have to furnish your own, but all the rods bolts looked ok. If it wouldn't be ok I have some other 1.9 stock rods that are ok we could work something out on if needed. I am looking to sell it all and not separate it.
