Author Topic: Anyone interested in aluminum thermostat housings?  (Read 4828 times)
November 10, 2015, 06:53:08 am
« on: November 10, 2015, 06:53:08 am »
I have a guy that I sell to that does aluminum, bronze, and some iron castings. He is looking for short run aluminum work. I figured if the t stat housings would be a thing, as long as no one else is making them that I see. If you all are interested I would take him one as a pattern and see how much. If no interest I will let it go.
Reply #1November 10, 2015, 04:40:20 pm
RunninWild
  • 609
Re: Anyone interested in aluminum thermostat housings?
« Reply #1 on: November 10, 2015, 04:40:20 pm »
I'd be interested in a modified housing if he could do it. Basically need the lower coolant hose outlet to be cut back and have a 90 degree barb installed in its place. I was going to try brazing it but if he could do it professionally thatd be way better.
Also the Suzuki swap crowd would definitely be interested in a aluminum housing that could be installed in the opposite direction. With hose routing in our engine bays all the hoses run straight into the motor mount which makes it quite difficult to get it all together without kinks
« Last Edit: November 10, 2015, 04:42:52 pm by RunninWild »
Reply #2November 11, 2015, 09:46:11 am
« Reply #2 on: November 11, 2015, 09:46:11 am »
Draw it and he can do it, but it isn't free. All I could do is take him what you want.
Reply #3November 11, 2015, 10:07:30 am
Ian0391
  • 119
« Reply #3 on: November 11, 2015, 10:07:30 am »
I would buy a stock aluminum one in a heart beat
Sent from my SM-G920W8 using Tapatalk
Reply #4November 11, 2015, 01:05:50 pm
RustyRabbitGuy
  • 29
« Reply #4 on: November 11, 2015, 01:05:50 pm »
Mk1 gasser's came with these aluminum elbows from the factory, can usually find them in the junk yards for cheap aswell.
81 Caddy 1.6TD
76 Rabbit 1.8t
03 Jetta ALH
Reply #5November 11, 2015, 04:35:22 pm
monomer
  • 414
« Reply #5 on: November 11, 2015, 04:35:22 pm »
I found a source for the OE on these, as I have a BRAND NEW one in the garage right now.
I'll have to find it to get a part number. They're out there.
www.michiganvw.org
Reply #6November 12, 2015, 05:56:56 am
« Reply #6 on: November 12, 2015, 05:56:56 am »
Post it up
