Author Topic: Wanted: AAZ pump, injectors, and pipes  (Read 4845 times)
October 02, 2015, 09:04:06 am
ryanoceros
  • 10
« on: October 02, 2015, 09:04:06 am »
I have an AAZ long block that was built up using the original 1.6TD JX parts from the engine it replaced.
I would like to buy an AAZ pump, injectors and the pipe set so I can upgrade to the stock configuration. I am most likely going to have Giles rebuild the pump and injectors, and so I am really looking for quality cores.
Shipping would be to Seattle.
Thanks for your help!
P.S. I would also be interested in the sprocket and bracket for the pump, if available.
Reply #1October 08, 2015, 08:17:36 am
ultimagtr
  • 6
Re: Wanted: AAZ pump, injectors, and pipes
« Reply #1 on: October 08, 2015, 08:17:36 am »
I have an AAZ pump with sprocket as well as an ALH sprocket that I will throw in. I'd like to get $200 for everything. let me know
Reply #2October 08, 2015, 01:21:07 pm
shortysclimbin
  • 138
    • Performance Diesel Engineering
« Reply #2 on: October 08, 2015, 01:21:07 pm »
I have an aaz pump with a 10mm head assembly on it I was going to use on my mtdi, but stuck with the Cummings 12mm pump instead (more fuel for compound setup).  I was asking $275 plus shipping for it obo.  PM an email or phone and I can send photos.  It is off a car with 70kkm. The 10mm head is from an alh with 50kmi.
Reply #3October 21, 2015, 06:17:42 pm
dontdoemyourself
  • 110
    • www.clearviewmt.com
« Reply #3 on: October 21, 2015, 06:17:42 pm »
I have a set of 4 injectors
1982 Vanagon diesel mTDi
1982 Jetta coupe - AHU/O2A project
1977 Scirocco Champagne 1.8 RV / Digi2
1963 Microbus Panel camper
05 Audi Allroad 6spd
01 Toyota Tundra V6 5VZFE/ 5 speed
