Author Topic: 1993 AAZ to AHU swap HELP!!  (Read 6402 times)
August 26, 2015, 05:50:20 am
Skippy594
  • 7
« on: August 26, 2015, 05:50:20 am »
My problem has gotten deeper and now my car is going to need a motor swap. I've been searching since my initial post for an AAZ but, man.... There isnt one anywhere near me for sale.
My next question I guess is, does anyone have a good AAZ for sale for a reasonable price in or around Ontario, Canada? I'm willing to take a whole car for the motor and, I'm willing to drive some distance to pick it up.
The next question I have after that is, I've heard and read around on the internet that I can swap in an AHU engine if I reuse my AAZ injection pump. Is this correct? The VW mechanic I know really well says I can only replace the AAZ with an AAZ but, again.... Everything I read online says I can swap in an AHU with my injection pump. Which is it and, if I can, whats involved in the swap?
Thanks again for all the helpful info! :D
Reply #1August 26, 2015, 06:04:47 am
Re: 1993 AAZ to AHU swap HELP!!
« Reply #1 on: August 26, 2015, 06:04:47 am »
You need a TDI pump for the ahu to run right. Whether that is MTDI or a full electronic swap TDI pump it will be needed. If the aaz pump worked un modded then no one would be building MTDI pumps or buying land rover pumps.
Reply #2August 26, 2015, 01:56:56 pm
« Reply #2 on: August 26, 2015, 01:56:56 pm »
Canadacatylist.com probably have AAZs and they are in Ontario...
I've got an AHU with a Land Rover 300TDI pump in place of the AAZ in my Jetta. It's an easy-ish swap. The AAZ pump will NOT work.
Reply #3August 27, 2015, 02:19:15 am
Skippy594
  • 7
« Reply #3 on: August 27, 2015, 02:19:15 am »
Ok, great.... Thanks guys.
