Author Topic: Ignore. Avoid the temptation to click.  (Read 5724 times)
August 11, 2015, 07:40:13 am
« on: August 11, 2015, 07:40:13 am »
The moment has passed. I will update this thread when I'm going back. It might be a few years away though.
I'm heading to the wreckers on Friday all going well. If you need any parts let me know and I'll pull them for you. I'll inspect them as best I can and won't keep anything that looks questionable. I can't test anything electronic or check mileage. Please only tell me you are interested in parts if you have the money to purchase and will follow through. I have don't have a lot of time at the yard and don't want to pull parts that you won't end up buying.
Cars available:
91 Jetta NA - broke timing belt - no pump/injectors
Multiple AAZs - no pumps, injectors have been exposed to weather
Multiple AHU/1Z - no pumps or injectors or ECUs
Multiple ALH - No pumps or injectors
A BEW - no injectors
A BHW - no injectors
Prices are as follows regardless of what car they come off: (shipping is included. If in the USA, prices are USD, if in Canada, prices are CAD)
Head w/ cam: $240
Turbo: $200 (VNT will be $230 shipped due to larger box required)
Intake manifold: $90
Exhaust manifold: $90
Vacuum pump: $55
Intakes hoses (airbox to turbo): $40
Intake hoses (turbo to intake): $30
Intercooler hoses: $40 each, complete set $140
Intercooler: $110
Fuel hard line set: $45
Cluster/instrument panel: $80
Anything else, just ask.
If you are buying multiple things and I can combine them for shipping I will and give you the difference. Some things can't be combined like a head and a turbo. Due to size/weight, they each need their own box.
« Last Edit: August 14, 2015, 03:27:53 pm by burn_your_money »
Reply #1August 11, 2015, 10:59:54 am
Tylenol
  • 41
Re: FS Junkyard run - lots of diesels - Friday!
« Reply #1 on: August 11, 2015, 10:59:54 am »
On the BEW and BHW the turbos are vnt1749 correct? I'm looking to upgrade want the GTB series if even possible to find!
Reply #2August 11, 2015, 11:33:38 am
« Reply #2 on: August 11, 2015, 11:33:38 am »
Sorry, turbos aren't my strong suit. What are you looking for exactly and what car does it come on?
Reply #3August 11, 2015, 12:19:39 pm
Tylenol
  • 41
« Reply #3 on: August 11, 2015, 12:19:39 pm »
Looking for a GTB1756vk or VL which I know are long shots but never hurts to ask! Couldn't tell you what they go on other then VW uses them and my MTDI is in a tacoma
Reply #4August 11, 2015, 05:39:05 pm
« Reply #4 on: August 11, 2015, 05:39:05 pm »
That helps, I'll see what is there.
Reply #5August 12, 2015, 05:20:07 am
Tylenol
  • 41
« Reply #5 on: August 12, 2015, 05:20:07 am »
Cool thanks man if you find one in decent shape I'll take it!
Reply #6August 15, 2015, 06:55:07 pm
canadacatalyst
  • 34
    • canadacatalyst
Re: Ignore. Avoid the temptation to click.
« Reply #6 on: August 15, 2015, 06:55:07 pm »
looking for bew turbo actuator that holds vacuum...
many vw diesel used parts on hand
1988-2008 jetta, golf, passat, new beetle
www.canadacatalyst.ca
Reply #7August 15, 2015, 11:17:44 pm
rallydiesel
  • 1880
« Reply #7 on: August 15, 2015, 11:17:44 pm »
1756 are not oem vw turbos in North America.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #8August 18, 2015, 05:07:58 am
Tylenol
  • 41
« Reply #8 on: August 18, 2015, 05:07:58 am »
Or the KKK BV43b the only option in America for a turbo?
Reply #9August 18, 2015, 07:06:36 am
92EcoDiesel Jetta
« Reply #9 on: August 18, 2015, 07:06:36 am »
Did you get a MK2 diesel instrument cluster with tach?
