Author Topic: Everything for sale  (Read 3931 times)
August 08, 2015, 04:09:44 pm
idi-tracker
  • 12
    • American Speed Center
Everything for sale
« on: August 08, 2015, 04:09:44 pm »
So my Geo Tracker project is on indefinite hold, Selling a Fresh VW 1.6-TD motor and Acme adapter kit. Plan was for VW 1.6 TD, Toyota 5-speed trans, dual Toyota Transfer cases, Toyota axles front & rear.
Motor is a 1984 1.6TD,, block has been cooked,cleaned,decked,bored. Have a set of Kolbenschmidt pistons, H-Beam Connecting Rods, ARP Head studs & Main Studs, Total seal top rings, Calico coated rod & main bearings, auxiliary shaft has been lightened & calico coated also, along with the auxiliary shaft bearings. New German gaskets & seals, oil pan gasket/windage tray, new water pump,timing belt, Also have 1 other complete vw 1.6 td (its apart), and a 1.6td short block, couple of turbos, injection pumps, etc. Motor needs put together
Acme adapter kit is for a VW 1.6TD to a Toyota 5-spd trans (have also),motor mounts, block mounts, Acme flywheel, New Spec stage3 clutch,
Plus alot more, will post pics, Located in Red Lion, Pa.. as far as price goes, it will depend on what all you want. Let me know
“Fighting for freedom is like screwing for virginity.”
Reply #1August 11, 2015, 12:21:24 pm
Tylenol
  • 41
Re: Everything for sale
« Reply #1 on: August 11, 2015, 12:21:24 pm »
What year and gear ratio are the axels?
Reply #2September 04, 2015, 04:58:12 pm
Orb95
  • 18
« Reply #2 on: September 04, 2015, 04:58:12 pm »
What turbos do you have laying around? Looking for a good turbo for my 1.6. Has a t3 right now.
