Author Topic: 1.6 CR IDI into 81 Rabbit Convertible (Cabriolet)  (Read 4989 times)
July 26, 2015, 02:48:07 pm
rs899
  • 647
« on: July 26, 2015, 02:48:07 pm »
This "project" has been ongoing for almost 10 years now.  First I was going to just get the original EN engine going.  Then I was going to pull and rebuild it.  Then I was going to swap in JH (actually did).
But I'm a dieselhead at heart so eventually realized I had enough old CR parts to convert.  I had a CR shortblock that I had bought from MOFOCO in '94 that only did like 30k miles before the center bearing trashed the crank. So, I repistoned that and got another crank and I am about to light that puppy off in the car in the next few days.  But I am going to just run it off the battery and a small fuel can, without going through the car wiring or gas tank.
Question is , when I eventually get it running on the proper wiring, I know I need to bypass the fuel pump wiring somehow so the the ignition will engage the starter.  Anyone know how?
« Last Edit: July 26, 2015, 03:08:20 pm by rs899 »
Reply #1July 30, 2015, 10:28:36 am
billybobf
  • 318
    89 golf 1.8 digi, 1.6 na in pieces in the shop
Re: 1.6 CR IDI into 81 Rabbit Convertible (Cabriolet)
« Reply #1 on: July 30, 2015, 10:28:36 am »
Ok, what is CR meaning? Normally I would think common rail, but then IDI and 94 say no?
Reply #2July 30, 2015, 11:59:10 am
rs899
  • 647
« Reply #2 on: July 30, 2015, 11:59:10 am »
CR is the engine code, as in  one of those old creaky 11mm blocks.  Yes I know about the current best practice to buy studs, but I started this business 21 years ago before anyone knew better (Al Gore hadn't invented the internet, can you imagine life before forums like this?).  I haven't ruined a block yet, and I have already torqued the head to final value with no obvious ill effects.  Do I feel lucky?  Youbecha..
'94 is when I bought this block (probably manufactured around 1981) as an assembled shortblock.  Evidently the MOFOCO morons didn't center the thrust bearing as it eventually ate up its crank.  I rediscovered it and thought I would put it to use.  (Actually, billybobf, it contains the O/S pistons you sold me via theman53 about three years ago...when you retire eventually projects find a way to get moving)
« Last Edit: July 30, 2015, 12:33:05 pm by rs899 »
Reply #3July 31, 2015, 11:16:34 pm
billybobf
  • 318
« Reply #3 on: July 31, 2015, 11:16:34 pm »
The three way deal that came out of a fresh built 11mm block that cracked at the oil supply head bolt . I remember those pistons! Too bad those rings only had less than 500 miles on them. I remember the deal! They were n/a pistons and theman was in such a hurry to get a set
Reply #4August 01, 2015, 05:03:51 am
rs899
  • 647
« Reply #4 on: August 01, 2015, 05:03:51 am »
I put Grant rings on them.  I have them on my Jetta and haven't burned much of anything on it in 80k miles, with less than perfect bores on it.  Fingers crossed on this cabby.
