Author Topic: A/C issues  (Read 5667 times)
July 23, 2015, 07:46:10 pm
fdnyguy
  • 499
A/C issues
« on: July 23, 2015, 07:46:10 pm »
As usual, I come to the best. My 98 TDI has ice cold a/c. After 45-60 min, it warms up, I get the white vapor coming out of the vents and even shutting it off for 30 or so min, its not the same. I cant use the max a/c because I think the foam padding that sealed the door is gone and I get nothing on max. But normal a/c on 3-4 is awesome til that 45-60 min.  Your thoughts?
Stay safe, stay well. Jimmy.
Never forget what a "Religion of Peace" did on 9/11/01.
2015 Passat TDi. 27k
1998 Jetta 1.9TTDi 228k .
2002 F250 7.3 TD   63,000 miles. Sold.
1980 Mack CF Fire Engine. Working on it.
2007 Dodge MegaCab 5.9 Cummins. Nice, but plagued with issues
Reply #1July 24, 2015, 01:34:15 am
air-cooled or diesel
Re: A/C issues
« Reply #1 on: July 24, 2015, 01:34:15 am »
if as you say, the foam is around the system, take it apart and get that foam out of there, dont run a/c till you do it,, you can be stuffing a/c system and vents, thereby the evaporator is clogged and if you hopefully havent damaged anything,,it might be ok, the sensors pick this up and shut off a/c,,failsafe, hopefully it worked, you can, with vents apart get some aluminum tape(from wallymart is fine) and some glue, i use good glue, not that regular spray glue, and fix vent doorS
Reply #2August 16, 2015, 10:21:25 am
smutts
  • 720
    ClackClackClackClackClack
Re: A/C issues
« Reply #2 on: August 16, 2015, 10:21:25 am »
Is VW still using that horrible foam that crumbles to dust? ::)
Reply #3August 16, 2015, 06:25:04 pm
Re: A/C issues
« Reply #3 on: August 16, 2015, 06:25:04 pm »
Yes, yes they are... Or at least they have continued through the Mk4s using it... Can't tell for sure till the car is 10 years old.
