Author Topic: Rover 200/300 compared to a Giles Super Pump.  (Read 2114 times)
June 25, 2015, 01:11:14 pm
heywier427
  • 21
« on: June 25, 2015, 01:11:14 pm »
Read that the Rover 200/300 is capable of 175hp +/-.
Is there really a need to have Giles pump built?
Modifying the Rover pump to fit into the 1.6 block does not sound difficult at all.
I am a noob.  What am I missing?
Thanks.
Reply #1June 25, 2015, 02:04:12 pm
Re: Rover 200/300 compared to a Giles Super Pump.
« Reply #1 on: June 25, 2015, 02:04:12 pm »
The LR pump is specifically suited to direct injection engines.  With one fitted to a 1.6, the aggressive timing advance, 11mm plunger and more abrupt camplate profile would all make for a VERY rattly engine.
Reply #2June 25, 2015, 08:13:53 pm
« Reply #2 on: June 25, 2015, 08:13:53 pm »
Yup. You need a pump set up for what you're running. The Rover pump works on TDI engines due to both engines being designed for the same Bosch injection system. An IDI is a different animal.
