Author Topic: AAZ Crank timing mark?  (Read 2926 times)
June 07, 2015, 10:58:33 am
goomicoo
  • 2
« on: June 07, 2015, 10:58:33 am »
I'm doing an AAZ swap into my Vanagon and would like to do the timing belt before I install the engine.
The transmission is not mounted and there is no timing mark on the crank pulley that I know of.
Is there one on the vibration dampener? I can't see any marks on the block to line one up with either  :P
Is there a tool to use on the crank pulley to hold it @ TDC?
Thanks for the help, I'm new to AAZ's  ;D
« Last Edit: June 07, 2015, 09:35:16 pm by goomicoo »
Reply #1June 07, 2015, 09:55:14 pm
RunninWild
  • 609
Re: AAZ Crank timing mark?
« Reply #1 on: June 07, 2015, 09:55:14 pm »
There should be one on the flywheel. If you haven't taken the belt off already just mark each sprockets location in relation to the block
Reply #2June 13, 2015, 10:31:20 pm
starrd
  • 128
« Reply #2 on: June 13, 2015, 10:31:20 pm »
tool can be found here: http://www.metalnerd.com/cat03.htm
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
