Author Topic: Mk2 1.6 na waterpump leaking  (Read 3105 times)
June 03, 2015, 04:22:11 pm
nissannx
  • 75
« on: June 03, 2015, 04:22:11 pm »
92 mk2 1.6 na power steering
My water pump is leaking and was wondering if there is a walk through online on how to replace it. I tried google but didn't come up with a great walk through
Anywhere in canada to order parts?
Thanks
Reply #1June 03, 2015, 07:26:22 pm
Re: Mk2 1.6 na waterpump leaking
« Reply #1 on: June 03, 2015, 07:26:22 pm »
The water pump is common to just about every pre 99 8V 4 cylinder VW so your closest decent parts store will have it.
The pump is definitely a pain. The book method is to pull the timing belt and do it from the timing belt side. You also can remove the alternator and power steering pump and pull the entire housing. If it hasn't been done for a long time and you live somewhere rusty I'd pull the entire housing.
Reply #2June 04, 2015, 01:38:06 am
nissannx
  • 75
« Reply #2 on: June 04, 2015, 01:38:06 am »
Is there a replacement brand that's better? Should I get bosche?
Reply #3June 04, 2015, 03:25:28 am
nissannx
  • 75
« Reply #3 on: June 04, 2015, 03:25:28 am »
Reply #4June 04, 2015, 11:12:59 am
« Reply #4 on: June 04, 2015, 11:12:59 am »
Geba and Hepu are good brands.  I wouldn't hesitate to use a Bosch.  Never heard of Thermex personally.
Reply #5June 10, 2015, 01:52:37 pm
sgnimj96
  • 185
« Reply #5 on: June 10, 2015, 01:52:37 pm »
   I remember on my MK1 the upper 2 bolts for the waterpump housing were hard to get to because of the injection pump.     Had to cut an end wrench in half to get in there,   maybe a curved wrench works for that.    Next time I did it was with the IP off.
  The o-ring seal for the waterpump is the same size as for the thermostat;  they may look different,   because the thermostat seal gets changed more often and is not smashed flat like the waterpump seal will be.
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
