Author Topic: Urms mk2 mTDI  (Read 11193 times)
May 27, 2015, 12:47:19 pm
urmas
  • 43
Urms mk2 mTDI
« on: May 27, 2015, 12:47:19 pm »
Hey everyone, after reading a while, thought I'd register.
Car is a 89 Mk2, that had 1.3 gasoline with 4 spd gearbox. Bought a JR engine swap with trans, which turned out to run more on engine oil than diesel, and luck threw an AFN block in front of me. So the car runs now with that and TD bits - pump, intake, turbo, etc.
Not much of a power monster but it gets me arround town, and the speed limit is 90 km/h  ;D
will go probably 110 km/h but i have not tried yet, there are still things to finish with the swap.
I am also exploring my options of getting up to stock AFN power mechanicaly, so far the easiest seems a LR300 pump, of which im eyeing  few on the ebay.
'89 Mk2 AFN mTDI
Reply #1May 27, 2015, 05:23:45 pm
Re: Urms mk2 mTDI
« Reply #1 on: May 27, 2015, 05:23:45 pm »
They stock LR300 pump is actually tuned for more like 120 HP out of the box, so it'll exceed stock AFN power without doing anything. Just keep an eye, they pop up all the time.
Reply #2May 28, 2015, 02:44:39 am
urmas
  • 43
Re: Urms mk2 mTDI
« Reply #2 on: May 28, 2015, 02:44:39 am »
What would i need to do to the LR pump, to be able to keep the stock JR turbo at least for a while? Turn down fueling, what else?
The swap has left my funds depleted, as the car has been partially resprayed and alot of things have been replaced to pass MOT.
'89 Mk2 AFN mTDI
Reply #3May 28, 2015, 07:27:43 am
Re: Urms mk2 mTDI
« Reply #3 on: May 28, 2015, 07:27:43 am »
Nothing. Maybe turn up the boost on the JR turbo, it should be a K24 or K14, either will happily do 15 PSI even without an intercooler.
Reply #4May 28, 2015, 09:57:42 am
urmas
  • 43
Re: Urms mk2 mTDI
« Reply #4 on: May 28, 2015, 09:57:42 am »
Great. I have also a mk3 intercooler with incomplete piping laying around for the time i fit a proper intake manifold (JR mani atm, when i fitted it i had some doubt whether it would ensure proper seal but i guess it does).
Cut out middle resonator, what was once part the gasoline exhaust system, and replaced it with 50mm pipe, boost pressure rose to 6 psi and top speed to whopping 120 km/h, enough for a daily driver i guess.
Put on plastic arch trim and took some pics, behold:
« Last Edit: May 28, 2015, 10:02:31 am by urmas »
'89 Mk2 AFN mTDI
Reply #5May 28, 2015, 04:10:08 pm
Re: Urms mk2 mTDI
« Reply #5 on: May 28, 2015, 04:10:08 pm »
Like the rims
Reply #6June 09, 2015, 06:39:43 am
urmas
  • 43
Re: Urms mk2 mTDI
« Reply #6 on: June 09, 2015, 06:39:43 am »
I have found a LR Discovery pump in a yard not far away, they said its part nr is 0460414136, can anyone confirm if this is a compatible unit?
'89 Mk2 AFN mTDI
Reply #7June 09, 2015, 08:14:29 am
Re: Urms mk2 mTDI
« Reply #7 on: June 09, 2015, 08:14:29 am »
From what I can find yes, that should be a workable pump.  It appears it is the 'immobilizer' version which has a box around the fuel shutoff solenoid, I'm not sure what is required to get rid of that.
Reply #8June 09, 2015, 11:36:57 am
urmas
  • 43
Re: Urms mk2 mTDI
« Reply #8 on: June 09, 2015, 11:36:57 am »
A quick search shows the immobilizer solenoid can be worked arround, so ill try to pick it up tomorrow.
'89 Mk2 AFN mTDI
Reply #9June 11, 2015, 04:41:35 am
urmas
  • 43
Re: Urms mk2 mTDI
« Reply #9 on: June 11, 2015, 04:41:35 am »
Here it is
Barely visible, but ERR6700 is there
No sprocket though, so what sprocket should i use? Post pic if possible.
« Last Edit: June 11, 2015, 04:47:45 am by urmas »
'89 Mk2 AFN mTDI
Reply #10June 12, 2015, 05:40:52 am
urmas
  • 43
Re: Urms mk2 mTDI
« Reply #10 on: June 12, 2015, 05:40:52 am »
Scoured the nearest breakers for a suitable IP pulley, from what ive seen this looks to be not far from what i need, but im not sure about the fitment. It was on a e-pump from a mk4, i think 1999, no code though as the pump is off the engine.
Is this what im looking for?
'89 Mk2 AFN mTDI
Reply #11June 12, 2015, 05:56:35 am
Re: Urms mk2 mTDI
« Reply #11 on: June 12, 2015, 05:56:35 am »
Yes, if the offset is the same, but if you get the pulley and the hub it should work fine. I think libbydiesel has commented on that elsewhere as I have no firsthand experience.
Reply #12June 12, 2015, 06:56:43 am
urmas
  • 43
Re: Urms mk2 mTDI
« Reply #12 on: June 12, 2015, 06:56:43 am »
Thanks alot, ill visit the breakers tomorrow again  8)
'89 Mk2 AFN mTDI
Reply #13June 12, 2015, 08:28:32 am
Re: Urms mk2 mTDI
« Reply #13 on: June 12, 2015, 08:28:32 am »
Yes, grab the Mk4 pulley and the hub. You'll need to bring a puller to get it off, plus a counter hold tool to undo the center nut. That's exactly the setup I'm using on mine.
Reply #14July 21, 2015, 05:30:52 am
urmas
  • 43
Re: Urms mk2 mTDI
« Reply #14 on: July 21, 2015, 05:30:52 am »
'89 Mk2 AFN mTDI
