Diesel Swaps
BEW to mtdi
Topic: BEW to mtdi (Read 10255 times)
May 07, 2015, 12:59:47 pm
Dieselpower74
User+
BEW to mtdi
May 07, 2015, 12:59:47 pm »
So I just picked up a BEW tdi and the cam lope has Been flattened but bottomed is fine. So I was thinking can you add a alh head to the BEW block and run the injction pump braket on it with all accessories then add a mtdi pump to it.would that work? It Is this going to be drop into a mk1 rabbit. I'm might keep then head and have the cam swapped and maybe doing the howl BEW swap but just kinda want the little guy going for now. Also would a o2o bolt to the engine aswell
May 07, 2015, 01:27:18 pm
Re: BEW to mtdi
May 07, 2015, 01:27:18 pm »
I have not done so but I'm going to say yes. If memory serves, I read of someone who replaced an ALH block with a BEW block. The mTDI would then be easy.
May 07, 2015, 01:30:06 pm
Dieselpower74
User+
Re: BEW to mtdi
May 07, 2015, 01:30:06 pm »
Also me im trying to finD out if my old pump braket will work for the passager side engine mount
May 07, 2015, 01:30:46 pm
Dieselpower74
User+
Re: BEW to mtdi
May 07, 2015, 01:30:46 pm »
Ment to say awesome at the beginning lol
May 07, 2015, 06:34:45 pm
Whitbread
User+
Re: BEW to mtdi
May 07, 2015, 06:34:45 pm »
ALH head will bolt to a bew block just fine. I'm 99.9% sure the ALH accessory bracket will bolt on also. But BEW valves are sunk flat in the head. So unless you pocket the pistons, or sink the ALH flush with the head, you'll have P2V contact.
As for the side engine mount, I've never tried. My bew is in a ski boat.
02 Jetta ALH TDI, 2260vk+02M
97 B4V ALH TDI, compound turbos + haldex awd
81 Caddy MTDI AHU
07 Arctic Cat 700 turbo diesel
90 Corrado ALH, 02M + haldex in progress
87 K10, Detroit 4-53T with twins
04 BEW going in 91 Ski Challenger boat
May 07, 2015, 07:08:34 pm
Dieselpower74
User+
Re: BEW to mtdi
May 07, 2015, 07:08:34 pm »
See I was wondering that. Thank you for letting me now do you know how much I have to shafe off the piston to except the alh head? Would it be easyer to just do the whole BEW swap with wiring harness and computer ext?
May 07, 2015, 07:27:41 pm
Dieselpower74
User+
Re: BEW to mtdi
May 07, 2015, 07:27:41 pm »
I wonder if BHW pistons would work?
May 12, 2015, 06:29:39 am
Dieselpower74
User+
Re: BEW to mtdi
May 12, 2015, 06:29:39 am »
Or can alh tdi piston be installed on a BEW rod.
May 12, 2015, 09:04:40 am
Re: BEW to mtdi
May 12, 2015, 09:04:40 am »
Yep, you can put ALH pistons on PD rods, just not the other way around.
May 12, 2015, 11:47:04 am
Dieselpower74
User+
Re: BEW to mtdi
May 12, 2015, 11:47:04 am »
Ok so I have been looking into pocketing the BEW pistons to except the alh head and I can't find measurement on how much should be machined off the piston. Dose anyone know how much should be taking off the BEW piston to except the ALH head so there's no piston to valve interference!
And thank you everyone for the help the little mk1 going to be fun here soon!
May 22, 2015, 11:44:45 am
shortysclimbin
Re: BEW to mtdi
May 22, 2015, 11:44:45 am »
Its not a static number, hence why no one can reply. What you are effectively asking is the following formula:
Piston protrusion - OEM BEW piston valve pocket depth - gasket thickness (I,II, or III hole)= Distance valves can protrude from head in TDC.
Next measure the valve protrusion from the head without the cam installed and subtract the above from it. This will tell you if the valves will contact when just assembling the head. If there is no room left then you will need to machine the valve pockets out. If there room left read on.
Ok so up till this point you know you can assemble it, but you haven't accounted for the camshaft. The camshaft, valve, valve springs, and hydrolic lifter turns rotational energy into linear energy based on the camshaft profile. you need to identify what lift your cam has at lower degrees of rotation and account for the valves moving faster or farther open than the pistons move. I have typically used .010-.030" clearance for static (without camshaft) clearances and then added around .030" for the valves depending on the profile. The key here is you need to have clearance at all times including after thermal expansion comes into play.
Reply #11
May 25, 2015, 08:00:30 am
Dieselpower74
User+
Re: BEW to mtdi
Reply #11 on:
May 25, 2015, 08:00:30 am »
Thank you for the information. It's helped I'm just now looking into the whole BEW tdi swap with the harness now seems th be easier
Diesel Swaps
BEW to mtdi
