For Sale/Looking For
Parts for Sale/Wanted
FS Toyota MTDI part out
Topic: FS Toyota MTDI part out (Read 6537 times)
May 03, 2015, 11:02:41 am
410
May 03, 2015, 11:02:41 am »
For sale. I recently parted out the first Toyota pick up I built with an AHU. If you need something and don't see it, send me a message.
First up, ACME adapter plate with flywheel and hardware. Missing the oilite pilot bushing and one of the top bolts that hold the plate to the motor. $200obo plus shipping. Sold!
PD150 intake and steel race pipe with 2 ports for wastegate, LDA reference etc. These ports can be blocked with an M6 bolt. $100 plus shipping.
Passenger side motor mount and power steering bracket with built in belt tensioner. $50 plus shipping.
Complete turbo set up including 1.6td exhaust manifold, very robust adapter plate, gt1852 turbo from a jeep liberty and 2.5" exhaust that routes exhaust to stock toyota location. Turbo not shown in picture. $500 plus shipping.
Modified harmonic balancer with a pick up and bracket for making the tach work. $50 plus shipping
I have all kinds of piping, silicone couplers, manifolds, intercoolers, too much to list.
Last Edit: May 04, 2015, 08:22:58 pm by 410
Toyota truck 4x4 with Mtdi, M-vnt gt1749va, 11mm pump, fmic, smog .216 nozzles. Sold!
May 03, 2015, 10:17:26 pm
billybobf
89 golf 1.8 digi, 1.6 na in pieces in the shop
Re: FS Toyota MTDI part out
May 03, 2015, 10:17:26 pm »
will send PM on adapter plate and flywheel
May 04, 2015, 11:34:26 am
May 04, 2015, 11:34:26 am »
PM sent.
May 04, 2015, 05:57:14 pm
410
May 04, 2015, 05:57:14 pm »
Here's a few more pics. This is the flywheel, bolts and shim that came with the ACME adapter plate. The starter shim was cut out of the original toyota shim plate between the transmission and engine. The flywheel should be resurfaced before installing. I can do this if needed. Sold!
And the vnt-2060vb turbo. This turbo worked out really well in the truck. Almost no turbo lag. Also pictured is an oil filter adapter from a Fox. It's slanted back to allow enough clearance for the oil filter and cooler. This adapter fits the 1.6. I made an adapter for it to bolt up to the 1.9. I also have an oil filter adapter from an audi 1.8t that bolts directly to the 1.9. PM me if interested.
Last Edit: May 06, 2015, 07:30:19 pm by 410
May 04, 2015, 06:10:57 pm
billybobf
May 04, 2015, 06:10:57 pm »
dang, I will have to search for what the audi filter housing looks like.
I have a quantum north south for the 1.6 I have, but kinda leaning towards the 1z
May 06, 2015, 06:05:22 pm
410
May 06, 2015, 06:05:22 pm »
Using the same PD intake I have for sale, I installed one in my golf with an ALH. I made up a 1" adapter plate for the EGR which you can see in the picture and it bolts right up. Makes for a nice bolt on upgrade in flow without deleting the EGR. The EGR cooler bolts right up to it. Even the stock engine cover fits.
May 06, 2015, 07:11:56 pm
May 06, 2015, 07:11:56 pm »
Is the turbo an 1852 or 1852v? What's the stock application?
May 06, 2015, 07:25:07 pm
410
May 06, 2015, 07:25:07 pm »
Quote from: libbydiesel on May 06, 2015, 07:11:56 pm
Looks like I'm off on my turbo I.D. It's from a jeep liberty with the 2.8l diesel. ID parts lists it as vnt-2060vb.
Last Edit: May 06, 2015, 07:29:41 pm by 410
May 17, 2015, 09:39:41 am
lowrider12
Newbie
May 17, 2015, 09:39:41 am »
Will you sell race pipe by itself?
May 18, 2015, 12:04:32 pm
410
May 18, 2015, 12:04:32 pm »
Quote from: lowrider12 on May 17, 2015, 09:39:41 am
Yes, for sure but I can't guarantee that it will fit your intake. I've seen a couple different patterns. $25usd +shipping.
