Author Topic: FS: 1.6td build and stuff  (Read 3761 times)
April 24, 2015, 07:41:06 am
monomer
  • 414
« on: April 24, 2015, 07:41:06 am »
Looking to go Mtdi, will trade for a working AHU
Block1:
Started as n/a, original motor from car;
-All machine work done, sans oil squirters (bore, line hone, etc...)
-Kolbenschmit td pistons, new
-All ARP hardware, including head studs, mains studs, con rod studs (that's like, $400 in arp stuff)
-Improved 360 degree main bearing set
-Con rod bearing set (standard size)
-Complete engine gasket kit
-Oem oil squirters
All you will need for a shortblock is a IM shaft and an oil pump (both of these ended up elsewhere) Looking for around $800ish? make an offer. The machine work and arp stuff cost me that alone.
Block 2:
-Dropped precup
-Block is good, will need pistons/rods and a bore.
-TD block, has squirters/oil lines.
I have an entire garage full of 1.6d stuff, if you're in MI swing by and make an offer.
www.michiganvw.org
