Starwheel question
Topic: Starwheel question (Read 2483 times)
April 20, 2015, 07:58:45 am
jamzta
Newbie
Starwheel question
April 20, 2015, 07:58:45 am »
People say to turn it a little bit, why not tighten it the whole way? Could that cause any issues?
April 20, 2015, 08:33:46 am
Jetmugg
Re: Starwheel question
April 20, 2015, 08:33:46 am »
The question seems a bit vague. Can you elaborate with any additional detail?
Steve.
April 20, 2015, 08:39:48 am
April 20, 2015, 08:39:48 am »
If it's too tight (low) there won't be enough spring tension and fuel will come in faster than boost. You'll end up with high EGTs and smoke. This will only happen at WOT while boost is building though so you might not care.
April 20, 2015, 12:34:53 pm
April 20, 2015, 12:34:53 pm »
Won't make the car any faster but it will sure make big black clouds...
April 20, 2015, 07:33:40 pm
jamzta
Newbie
April 20, 2015, 07:33:40 pm »
After turning it way down, it does seem to have more smoke but more power too. I was just wondering if it would create any problems other then more smoke. My egt seem to be pretty good. I might back it off a little just for the heck of it. If its just more fuel without much if any gains doesn't sound very good to do all the way, oh well.
April 20, 2015, 08:51:40 pm
April 20, 2015, 08:51:40 pm »
Yeah it'll go faster as you turn it down to a point, but just cranking it to the bottom rather than finding the sweet spot is not beneficial. Might as well just crank the fuel screw all the way in and Damn the torpedoes.
The idea of the LDA is purely to reduce off boost smoke. It's a balance between the fuel screw and the LDA.
Last Edit: April 20, 2015, 08:53:43 pm by vanbcguy
April 21, 2015, 08:46:07 am
jamzta
Newbie
April 21, 2015, 08:46:07 am »
OK. Thanks for the help everybody.
Starwheel question
