Author Topic: n/a 1.9 diesel engine block.  (Read 2121 times)
April 16, 2015, 07:35:18 pm
felipe1f
  • 31
« on: April 16, 2015, 07:35:18 pm »
Hi,
Does anybody know if the 1.9 n/a engine block is the same as the AAZ turbo diesel engine?
I heard this from some guy that bought a 1.9 n/a engine from a dealer in California, that is what
the used VW diesel used engine dealer told him.
Thank you for any info you can provide.
Reply #1April 17, 2015, 10:16:39 am
Re: n/a 1.9 diesel engine block.
« Reply #1 on: April 17, 2015, 10:16:39 am »
Hi,
they are similar, have the same bore and stroke and both have oil squirters, the rods and pistons are slightly different though, the NA engines had longer rods with a higher mounted wrist pins.  over all though i'd see them as completely interchangeable, and the difference is with the internals not the block casting.
Reply #2April 17, 2015, 02:48:59 pm
« Reply #2 on: April 17, 2015, 02:48:59 pm »
I'd be surprised if the NAs had the oil bung cast or at least drilled and tapped in the back of the block. Fairly minor in the big scheme of things.
Reply #3April 18, 2015, 02:45:27 pm
felipe1f
  • 31
« Reply #3 on: April 18, 2015, 02:45:27 pm »
Thank you all for the information.
