Author Topic: Inaccurate fuel guage  (Read 3422 times)
March 31, 2015, 03:54:41 am
nissannx
  • 75
« on: March 31, 2015, 03:54:41 am »
1992 jetta diesel n/a
When my guage reads 1/4 tank I have no diesel left in my tank. How do I fix this?
Thanks
Reply #1March 31, 2015, 11:45:18 am
Re: Inaccurate fuel guage
« Reply #1 on: March 31, 2015, 11:45:18 am »
Two ways, one repaint the gauge so that 1/4 is really E.  The other is to rebend the arm on the float in the tank so that the resistance being produced by the sender is more in line with the gauge needs on the dash.  If you are looking at 1/4 tank on the gauge and are empty you need to bend the arm down some so that it sends the proper signal to the gauge.
Reply #2April 01, 2015, 09:01:56 am
nissannx
  • 75
« Reply #2 on: April 01, 2015, 09:01:56 am »
 Is there access in the trunk or do I drop the tank?
Reply #3April 01, 2015, 10:13:05 am
« Reply #3 on: April 01, 2015, 10:13:05 am »
If it is like the mk1 you can bend the top where the float attaches to the sender...not bend the wire, but the tab it hits when full or empty.
Reply #4April 01, 2015, 10:24:34 pm
« Reply #4 on: April 01, 2015, 10:24:34 pm »
I thought the Jetta had access from the trunk.  Remove liner and look for round ring and wires.  Tap the ring loose and remove gauge out the top.  Someone with a Jetta tell him if I am wrong.
Reply #5April 02, 2015, 04:56:20 am
Smoker
  • 255
« Reply #5 on: April 02, 2015, 04:56:20 am »
Mk2's do have access to the tank, I forget if it's in the trunk or under the back seat.
Reply #6April 02, 2015, 06:37:59 am
« Reply #6 on: April 02, 2015, 06:37:59 am »
Mine you can get to through the trunk 86 jetta
