Author Topic: return lines between injectors...  (Read 4011 times)
March 25, 2015, 06:58:01 am
Smoker
  • 255
« on: March 25, 2015, 06:58:01 am »
Where do you guys buy it?  Also the cap for #4?
Reply #1March 25, 2015, 11:27:56 am
Re: return lines between injectors...
« Reply #1 on: March 25, 2015, 11:27:56 am »
My local VW shop has a 100? foot roll.  autogeek or one of those  sites has reasonable kits as well.
Reply #2March 25, 2015, 03:06:05 pm
« Reply #2 on: March 25, 2015, 03:06:05 pm »
I use this:
http://www.mcmaster.com/#5549k31/=wgudki
Excellent hose that lasts MUCH longer than the black braid covered stock hose.  It has the benefit of being clear making diagnosis of air infiltration easier.  For the end plug I use a short piece of the hose and install a cut piece of appropriately sized drill bit shank or nail.  That method lasts much longer than the stock plugs and has the benefit that if it ever does begin to leak or suck in air, the end of the hose can be trimmed a little and re-installed.
Reply #3March 26, 2015, 08:46:02 am
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #3 on: March 26, 2015, 08:46:02 am »
I just use standard bulk fuel line I get down at the local NAPA store. They'll cut me off a piece however long I need. Never had a problem with it. For the end cap I just stuff a screw in there and put a hose clamp on it.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #4March 26, 2015, 07:56:00 pm
Smoker
  • 255
« Reply #4 on: March 26, 2015, 07:56:00 pm »
Brilliant.  I ordered some today.  Thanks.
Reply #5March 27, 2015, 07:35:34 am
Jetmugg
  • 530
« Reply #5 on: March 27, 2015, 07:35:34 am »
I've been using the black Viton stuff from McMaster....
http://www.mcmaster.com/#catalog/121/134/=whpo19
Steve.
Reply #6March 27, 2015, 07:37:17 am
Jetmugg
  • 530
« Reply #6 on: March 27, 2015, 07:37:17 am »
I use this:
Libby - does the clear stuff get brittle over time?
Steve.
Reply #7March 27, 2015, 08:27:18 am
« Reply #7 on: March 27, 2015, 08:27:18 am »
No, it doesn't get brittle.  I've used it for several years and it does not change its flexibility.  I've found that over several years, the ends of the tube do start to 'remember' the shape of the barbs and so can lose a bit of their 'grip'.  Snipping off the ends and pushing the tubing back on the barbs will refresh it for a few more years.  I do like the clear for diagnosis.  The injector jumpers always have air in them, but after shutdown, you can easily see if air is infiltrating as the bubbles will move from the leaking barb toward the return fitting.  If there are no leaks, after shutdown the air/fuel in the jumpers does not move.
Reply #8March 30, 2015, 04:08:53 pm
Whitetail
  • 15
« Reply #8 on: March 30, 2015, 04:08:53 pm »
I use the 1/4 nylon clear from home depot. Not sure if its better or worse than tygon but its only $6 for 10ft of it.
Reply #9April 03, 2015, 10:01:22 am
sgnimj96
  • 185
« Reply #9 on: April 03, 2015, 10:01:22 am »
       I think the nylon tubing gets hard after while,  maybe from the heat.
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
Reply #10April 03, 2015, 06:40:37 pm
  • 2931
« Reply #10 on: April 03, 2015, 06:40:37 pm »
 If you are in a hurry the clear vinyl works great for a year or so, is locally available and is real cheap.
 I'm going to stop using the motorcycle shop urethane line.
 It crackles like safety glass after a couple years.
Reply #11April 17, 2015, 07:16:45 am
air-cooled or diesel
« Reply #11 on: April 17, 2015, 07:16:45 am »
thanks for the info libb; going to love it when my shipment gets here and i can do clear lines all around; i just have to find some tubing; they had it; i need less than a foot(for 2 cars), and they sell it in 10ft lengths. i ll have to look around some,,
