Author Topic: What did you do to your car today?  (Read 145650 times)
Reply #180December 21, 2023, 07:53:08 pm
  • 4551
Re: What did you do to your car today?
« Reply #180 on: December 21, 2023, 07:53:08 pm »
Pulled the battery as I needed to Jump N Carry it this morning.  Took battery to store, man tests and says 94% good. Return home, clean ground to frame connection.  Fires right up.
How many times do we have to do that?  Well, if it is a VW, and you are having electrical gremlins dancing on your hood.  Clean the grounds and ring a bell.  Tah Dah, both go away.
Reply #181December 25, 2023, 10:25:13 am
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #181 on: December 25, 2023, 10:25:13 am »
I usually spray some of that battery terminal sealer stuff on the grounds. Seems to protect them from the elements.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
70 Bug
Reply #182December 25, 2023, 02:44:53 pm
  • 4551
« Reply #182 on: December 25, 2023, 02:44:53 pm »
I wanted to coat them in POR after I cleaned them.  Seal them up for a good long time.
Reply #183January 24, 2024, 10:13:49 am
pzookey
  • 8
« Reply #183 on: January 24, 2024, 10:13:49 am »
Nope the proportioning valve appears to be working properly so I did not mess with it.
Some people are like Slinkys, not really good foe anything but still brings a smile to your face as you push them down the stairs
Reply #184January 24, 2024, 08:04:06 pm
  • 4551
« Reply #184 on: January 24, 2024, 08:04:06 pm »
My brakes seem low on the pedal too and I have put two different Proportioning valves on and I still don't like the feel of the brakes.  Maybe in my case, it is MC problems.
Reply #185January 26, 2024, 01:54:12 pm
  • 5104
« Reply #185 on: January 26, 2024, 01:54:12 pm »
it can be hard to find a good master cylinder for an american made mk1. Are you driving the car? maybe it the master cylinder just isn't full bled?
Reply #186January 26, 2024, 07:36:18 pm
  • 4551
« Reply #186 on: January 26, 2024, 07:36:18 pm »
I don't drive it like I used to because I am enamored with the Hybrid Maverick right now.  But yes it is/was my daily driver.  I can't think that there is still air in the MC, I bench-bled it before I put it on a couple of years ago and I have pumped and pulled over two quarts of brake fluid through it in the last couple of months doing the proportional valve swapping.
It could be a bad MC.  Many get rebuilt poorly so I may put a gauge on the ports and see what I get for pressure and if it holds.  I can pump up the pedal and when I stand on it after that it will slowly sink to the floor.  That is a sign of poor seals in the MC if I remember my mechanic learning correctly.
Reply #187January 27, 2024, 06:10:38 am
  • 5104
« Reply #187 on: January 27, 2024, 06:10:38 am »
yeah that sounds like a bad master to me
Reply #188January 27, 2024, 08:48:48 am
RustyCaddy
  • 395
« Reply #188 on: January 27, 2024, 08:48:48 am »
You have likely seen them but if not there are a few MCs on The Samba classifieds that appear to be NOS but they are a little pricey these days (what isn't?). Not mine or anyone I know
« Last Edit: January 27, 2024, 06:01:09 pm by ORCoaster »
Reply #189January 27, 2024, 08:56:53 am
Dennis Froelich
  • 258
« Reply #189 on: January 27, 2024, 08:56:53 am »
I second RustyCaddys response!! Excellent source of OEM parts!!
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #190January 27, 2024, 06:02:41 pm
  • 4551
« Reply #190 on: January 27, 2024, 06:02:41 pm »
So now I need to add that one to the list of places to go.  I already spend too much time on Marketplace and CL as it is.
Maybe if the selection is better just drop those other two?
Reply #191January 28, 2024, 05:58:28 am
Dennis Froelich
  • 258
« Reply #191 on: January 28, 2024, 05:58:28 am »
Well worth the time Dale! I check Samba watercooled parts every day for hard to find parts.
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #192June 30, 2024, 08:42:01 pm
  • 4551
« Reply #192 on: June 30, 2024, 08:42:01 pm »
So today I decided to attack the diesel leak that has slowly been growing under the pickup after I parked it facing downhill on the street I live on.  I popped the hood and started poking around and found the filter was a bit loose from the bracket that holds it to the fender.  In working on that I feel the entire filter is loose on the bracket itself.  Ok a twist or two and that problem is solved.
Tighten the screws on the fender and that problem goes away.  But what about this hose that looks all shiny?  I got a towel and dried it off and I notice that is has a line or two on it that become shiny again.  So I took it off and it was nearly cracked at the banjo fitting that held it to the filter.  OK, a new one of them please, from the shed stockpile I went.
 I ended up replacing all the hose from the back of the firewall to the front of the IP.
In doing that I noticed that my alternator was a bit loose and that might have been the reason for the flickering dash light at low RPM and warmer than normal engine temp.  Got that tightened up and it started right up and didn't seem starved for fuel anymore.
Not good to have all those air leaks in the system when drawing fuel into the IP.  Maybe that is why it was cutting out some at 3500 RPM coming up the long hills.
