Author Topic: What did you do to your car today?  (Read 145638 times)
March 13, 2015, 03:30:52 pm
« on: March 13, 2015, 03:30:52 pm »
Doesn't seem like we have an active thread like this around here, so here goes! Post whatever little thing you got up to that doesn't warrant it's own thread.
Reply #1March 13, 2015, 03:34:37 pm
Re: What did you do to your car today?
« Reply #1 on: March 13, 2015, 03:34:37 pm »
My speedometer started randomly dropping while I was driving the other day and then completely went dead for several minutes this morning. I had to extend my wiring when I swapped to an 02A, so figured that was probably the cause. Removed everything I did previously and started from scratch, works fine now!
I had to yank my AWIC to get at that so I also dealt with a seeping fitting on the bottom of it that I've been avoiding dealing with. Hopefully no more leaks...
Finally since I think I have my oil leaks all figured out now I gave the engine bay a degreaser soak and a bath. Puuuurdy...
Now I'm off for a road trip down to Seattle. Fun fun!
Reply #2March 13, 2015, 06:09:53 pm
  • 4551
« Reply #2 on: March 13, 2015, 06:09:53 pm »
Last weekend it was new ball joints and leak chasing.  One on the coolant the other oil.  Today I noticed another small wet dot under the car up under the area it was dripping from before.  But on chasing down the possible leak area I wrote it off to the little bit of moisture from the hood.  Well, I am hoping so.
Reply #3March 17, 2015, 12:09:13 pm
Dakotakid
  • 1240
« Reply #3 on: March 17, 2015, 12:09:13 pm »
Well, I fed my car large amounts of full throttle (to keep those rings against those walls) while I drove around with Brian Williams and listened intently to his stories about his time in the war zone..........
Reply #4March 17, 2015, 09:41:48 pm
dontdoemyourself
  • 110
    • www.clearviewmt.com
« Reply #4 on: March 17, 2015, 09:41:48 pm »
Well, it was yesterday, but I checked into a scraping noise on my AAZ  in my Vanagon.. I went ahead and tried to fire it up, and it took forever.. ( think I backed my residual fuel screw out too far) then once it fired I pin pointed the noise.. I over tightened my timing belt and bent the stud it mounts to..  Weekend project #765. I may have adjusted my timing a little too far to the advanced side, .038" or ~.95mm.. I'll go back to .87-.89 when I redo it.
1982 Vanagon diesel mTDi
1982 Jetta coupe - AHU/O2A project
1977 Scirocco Champagne 1.8 RV / Digi2
1963 Microbus Panel camper
05 Audi Allroad 6spd
01 Toyota Tundra V6 5VZFE/ 5 speed
Reply #5March 18, 2015, 08:26:40 am
air-cooled or diesel
« Reply #5 on: March 18, 2015, 08:26:40 am »
i have 4 im switching work on right now, 2 mk2's the one i adjusted my brakes(booster), installed booster, bled brakes, parked her for a bit, the other mk2 im registering today and will put her on the road for the 1st time in a few years, minor svc, swapped out really old v-rated tires for road worthy my 14" spares. i now need 2 14"rims/spares. oh i had to buy a vac pump oring and put in and a little work and she fired up,
the other is a mk3tdi, having a little prob with a timing issue, have to get 2 parts and i can re-try.some one after i timed it went into the timing; now i cannt spot my tdc notch i had marked, headache.
Reply #6March 18, 2015, 05:27:15 pm
« Reply #6 on: March 18, 2015, 05:27:15 pm »
Sold my old 14" wheels... Turned down my fuel screw a tad as I've been leaving some fairly heavy clouds even when I don't want to.  Adjusted my idle upwards a tad to try and smooth out vibrations a bit... Stared at my pump and tried to convince myself to open it up to gov mod it, but decided to leave that for another day.
Oh and I took my "other" Bosch system in for service... my Bosch Benvenuto B30 espresso machine!  Yes, Bosch is just as bad as they are with their injection pumps - no service information is available anywhere, you can't get parts, only authorized service centers can do anything with it...
Reply #7March 19, 2015, 06:53:36 am
« Reply #7 on: March 19, 2015, 06:53:36 am »
cannt go without coffee whether or not im working on my cars, gl fixing it, bosch brewed coffee, i just buy mr.coffee or a $17 black&decker, and coffee no headaches
Reply #8March 19, 2015, 07:21:18 am
« Reply #8 on: March 19, 2015, 07:21:18 am »
I never would have bought the thing new but I acquired it for free.... Though I have had to pay for service a couple of times now.
Reply #9March 26, 2015, 07:51:32 am
« Reply #9 on: March 26, 2015, 07:51:32 am »
i have ins&reg for my other mk2 backup, some work, get all lights working, align, and other little stuff and she ll roll. only prob to motor is basically toast, i ll see if it ll hold together and keep on running, have to break her in.
Reply #10March 26, 2015, 12:09:23 pm
« Reply #10 on: March 26, 2015, 12:09:23 pm »
i had forgot all this other work, im going to tear down the front of motor, replace wp, keep coolant, retime.
Reply #11March 26, 2015, 04:22:34 pm
« Reply #11 on: March 26, 2015, 04:22:34 pm »
Got my gov mod done on my mTDI finally.  Wow, with the big cam in there it has NO trouble burying the tach needle.  I gotta look at my VNT boost map; I have it pulling off above 5K right now and this engine is still ready and willing to play in the upper ranges. :)
Reply #12March 27, 2015, 06:23:47 am
Dennis Froelich
  • 258
« Reply #12 on: March 27, 2015, 06:23:47 am »
Got my 96 GTI TDI out of the garage and drove it.....  ;)
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #13March 27, 2015, 04:11:29 pm
  • 4551
« Reply #13 on: March 27, 2015, 04:11:29 pm »
Yep, drove to and from work, need to check for rear bearing slop this weekend I get a shake at 35 now.  Already did the front end.  Might be tires too.
Reply #14April 05, 2015, 04:30:53 pm
« Reply #14 on: April 05, 2015, 04:30:53 pm »
had tore down front of 1 engine, new water pump and a good thermo, helps a lot.
, very little smoke now, i ll hit that hill again when i come back north and go up and down a few more times ;)
« Last Edit: January 21, 2017, 10:30:46 am by air-cooled or diesel »
