Author Topic: 1.6 Hydro TD part out  (Read 5127 times)
March 01, 2015, 06:29:56 pm
Trips_B
  • 57
« on: March 01, 2015, 06:29:56 pm »
Ok so heres the skinny.  I rebuilt this motor 3 years ago, Blew a head gasket overboosting and 2 AAZs fell into my lap.
the build thread on vortex so you know its real http://forums.vwvortex.com/showthread.php?5512933-My-86-TD-Jetta-build-restoration
and the parts: (the only thing ever purchased from prothe were the pistons)
OBO plus shipping from Kamloops, BC, Canada
now parting out
1.6 hydro block, the following was new at time of build
 -  1mm OS prothe pistons  ::) they still look new w/ topline rings
 -  rod bearings, crank bearings, IM bearings, oil pump, water pump
$150
Garrett T3 turbo
 - little side to side play
 - in and out oil lines
 - light grinding marks on the intake side to 'clock'
$50
Intake manifold w/bunged block off plate  which I used to initialize my MBC
$200
1.6 TD pump
 - running when parked
 - only played with max fuel screw
$100
1.6 TD pump
 - running before I broke the pressure reg on it
 - also needs IN bolt
 - Mild gov mod
$60 each - 2 Alternators both with W terminal
$40 - 1.6 complete injector lines
$100 - AGS tranny 90mm with 3 year old clutch kit
$100 - 1.6 Radiator 1.5 years old with slim fan
Also have a complete 86 jetta coupe shell for parts. anything you need shoot me an offer
 - tail lights
 - suspension
 - interior parts
 - motor mounts
all pictures on request, lets find a new VW for these parts.  email preferred bramer.ben @ gmail
cheers
« Last Edit: March 28, 2015, 10:36:09 am by Trips_B »
Reply #1March 02, 2015, 09:40:12 am
Dakotakid
  • 1240
Re: 1.6 Hydro TD part out
« Reply #1 on: March 02, 2015, 09:40:12 am »
Have requested head info in pm.
Reply #2March 02, 2015, 01:04:32 pm
juan.cobar
  • 8
« Reply #2 on: March 02, 2015, 01:04:32 pm »
Interested in turbo and intake manifold.
Reply #3March 04, 2015, 09:30:46 pm
Trips_B
  • 57
« Reply #3 on: March 04, 2015, 09:30:46 pm »
« Last Edit: March 08, 2015, 01:09:10 am by Trips_B »
Reply #4March 10, 2015, 07:37:11 am
dontdoemyourself
  • 110
    • www.clearviewmt.com
« Reply #4 on: March 10, 2015, 07:37:11 am »
Is the LDA on the &
$100 1.6 pump broken? I could use it's boost pin.
1982 Vanagon diesel mTDi
1982 Jetta coupe - AHU/O2A project
1977 Scirocco Champagne 1.8 RV / Digi2
1963 Microbus Panel camper
05 Audi Allroad 6spd
01 Toyota Tundra V6 5VZFE/ 5 speed
Reply #5March 14, 2015, 07:16:20 pm
cervelorod
  • 41
« Reply #5 on: March 14, 2015, 07:16:20 pm »
Need alternator bracketry, sell just that?
Ship to 98837
Rod
Reply #6March 18, 2015, 08:31:54 pm
Trips_B
  • 57
« Reply #6 on: March 18, 2015, 08:31:54 pm »
$100 pump pending sale
Will get a quote on alt brackets,  perhaps my mf oil dipstick and tube will fit your cy as well?
Block is now being parted out. IM shaft is gone
Bare with me on quotes and shipping i was in a roll over on sunday that crossed the hwy and then we got tagged by a semi
« Last Edit: March 18, 2015, 08:33:35 pm by Trips_B »
Reply #7March 28, 2015, 10:39:28 am
Trips_B
  • 57
« Reply #7 on: March 28, 2015, 10:39:28 am »
Sold:
head
IM shaft
turbo mani
Alt brackets
Pending:
Running TD pump and lines
block and transmission
Reply #8April 05, 2015, 12:58:17 pm
jumpnj82
  • 3
« Reply #8 on: April 05, 2015, 12:58:17 pm »
Still have the valve cover and tray and turbo for sale?
