Author Topic: AHU - spacer behind flywheel?  (Read 7471 times)
February 14, 2015, 07:30:04 am
Smoker
  • 255
« on: February 14, 2015, 07:30:04 am »
I'm putting together an ahu that's been sitting in my shop, partially disassembled, for a while.  When I attempt to bold the flywheel on, it makes contact with the plate/guard/whatever on the block.  What am I missing?  I vaguely remember something being behind the flywheel, but I have no idea where it would be...  help?!
Reply #1February 14, 2015, 06:05:23 pm
Re: AHU - spacer behind flywheel?
« Reply #1 on: February 14, 2015, 06:05:23 pm »
There is nothing behind the flywheel on my AHU....
I'm using an aftermarket South Bend flywheel though. Not sure if that makes a difference. Definitely not contacting the plate on the block.
Reply #2April 02, 2015, 08:46:40 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #2 on: April 02, 2015, 08:46:40 am »
I ran into this same issue about 6-7 years ago. I was installing a eurospec light weight single mass flywheel on an AHU for a friend. I had everything assembled and in the car and it wouldn't rotate. I pulled it back apart and ended up installing a 020's shim so the flywheel would clear the backing plate. What a PITA, GRRRR
here is the new flywheel that required the spacer vs the old one:
« Last Edit: April 02, 2015, 08:55:58 am by G60ING »
